Some more volume integral questions
togo
Formulas:
Shell Method: dV = 2pi(radius) * (height) * (thickness)
Disk method: dV = pi(radius)^2 * (thickness)
Question 1 (26-3-15)
Statement
Using Shell method, find the volume generated by revolving the region bounded by the given curve about the x-axis.
x = 4y - y^2 - 3, x = 0
Attempt
integrating:
4y^2 - y^3 - 3y = x
4/3y^3 - 1/4y^4 - 3/2y^2
at this point I would plug a boundary number into the variable, what number should it be?
Question 2 (26-3-19)
Statement
Using disk method, find the volume generated by revolving the region bounded by the given curve about the y axis.
y = 2(x^1/2), x = 0, y = 3
Attempt
y/2 = x^1/2
(y/2)^2 = x
y^2/4
(y^2/4)^2
y^4/16
is this the correct path?
Question 3 (26-3-21)
Statement
Using shell method, find the volume generated by revolving the region bounded by the given curve about the y axis.
x^2 - 4y^2 = 4, x = 3
Attempt
2pixy principal formula
isolate y
-4y^2 = 4 - x^2
-y^2 = (4-x^2)/4
-y^2 = -x^2
x = y
2pix^2 = 1/3x^3 = 9
but this answer is incorrect
Thank you for your time.
Statement
Attempt
integrating:
4y^2 - y^3 - 3y = x
Be precise in your setup. There are a number of errors in your work. I see no integral sign, I see no dy, and I see no 2pi in the front. As to the limits of integration, well the graph is a sideways parabola. Find the y-intercepts.
Statement
Attempt
isolate y
-4y^2 = 4 - x^2
-y^2 = (4-x^2)/4
-y^2 = -x^2
This is wrong. It should be
-y^2 = 1 - \frac{x^2}{4}
thanks for the tips how do you use latex
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
