Something that should be extremely simple - Blackbody Curve
  • Thread starter Thread starter Xyius
    Blackbody Curve
The discussion revolves around difficulties in plotting the blackbody curve at 2000K using the Planck Radiation Formula. The user is experiencing issues where the plotted curve resembles a symmetrical exponential decay rather than the expected blackbody curve. Participants suggest that the problem may stem from mishandling the plotting software or incorrect axis scaling, particularly with the range of values for wavelength. They emphasize the importance of checking the equation input for errors, such as parentheses, and recommend experimenting with the axis scales to properly visualize the peak of the curve. Overall, the consensus is that the equation is correct, and the user should focus on the plotting process.
Xyius
Hello!
I am having an issue with something that should be extremely simple. Essentially, all I am trying to do is plot the blackbody curve at 2000K in terms of the wavelength. The formula I am using can be seen here.. (Don't feel like typing it)
http://hyperphysics.phy-astr.gsu.edu/hbase/mod6.html
In the "Planck Radiation Formula" section, second box. Every time I try to plot it, it ends up looking like a normal exponential decay function, except symmetrical about the y axis, NOT the blackbody curve. I got the TA in my grad lab to help and he is also stumped. After calculating the numbers, I got the formula to be..
\frac{5 \times 10^{-24}}{\lambda^5}\frac{1}{e^{\frac{0.144}{2000 \lambda}}-1}
Can anyone shed light on this?
so you used the c = lambda * v equation right, solved for v = c / lambda and plugged it into get your equation in lambda
first how did you get lambda^5 in the first factor it seems it should be lambda^3
and second did you plot using lambda or v for the x-axis?
I used the equation labeled S_{\lambda}, it has a \lambda^5 term in it. I am using \lambdafor the x axis.
Okay this seriously is not making any sense. I keep trying to plot this thing, thinking I made some sort of error with units or something and I keep getting the same thing. What is going on?!
The equation is correct. You are probably mishandling the software. My guess is that the peak is squished too close to the Y-axis for you to see given the choice of coordinate scale. Play around with the axis scales and see what happens is my advice.
I keep scaling the axis and am not seeing anything I should be. Could someone else try plotting it and let me know how it works out?
Looks OK when I plot it. See attachment. You must be doing the plotting wrong.
You are probably messing up typing the expression into the computer or calculator. Check your parentheses and your range of values for lambda. If you are using something like Matlab, Mathematica, or IDL, it should be pretty simple. If you still can't figure it out, post the code.
