Sound of Music - Closed Organ Pipe
In summary, the first closed organ pipe has a length of 2.40m and produces a frequency of 71.46 Hz. When a second pipe is played at the same time, a beat note of 1.40 Hz is heard. This indicates that the second pipe is either 0.048 m or 0.0462 m too long, depending on whether the frequency is 70.06 Hz or 72.86 Hz. To eliminate the beat note, the length of the second pipe would need to be adjusted accordingly.
whitehorsey
192
1. One closed organ pipe has a length of 2.40m.
a. What is the frequency of the note played by this pipe?
b. When a second pipe is played at the same time, a 1.40 Hz beat note is heard. By how much is the second pipe too long?
2. f = nv/2L (n = 1)
change of f = absolute value of f2 - f1
3. a. f = nv/2L (n = 1)
= 1(343)/2(2.4)
= 71.46 Hz
b. change of f = absolute value of f2 - f1
-1.4 = f2 - 71.46 1.4 = f2 - 71.46
f2 = 70.06, 72.86
f = nv/2L
70.06 = 343/2L 72.86 = 343/2L
140.12 L = 343 145.72 L = 343
L = 2.4479 L = 2.3538
2.4 - 2.4479 = 0.048 m
2.3538 - 2.4 = 0.0462 m
Therefore, the second pipe is too long by 0.048 m or 0.0462 m, depending on whether the frequency is 70.06 Hz or 72.86 Hz. This difference in length is causing the beat note of 1.40 Hz to be heard. To eliminate the beat note, the length of the second pipe would need to be adjusted accordingly.
2.3538 - 2.4 = -0.0462 m
Therefore, the second pipe is either 0.048 m too long or 0.0462 m too short. This difference in length causes the beat frequency of 1.4 Hz to be heard. This can be explained by the interference of sound waves from the two pipes, resulting in constructive and destructive interference at different points in time, creating a beat or fluctuation in the overall sound.
FAQ: Sound of Music - Closed Organ Pipe
1. What is the "Sound of Music - Closed Organ Pipe"?
The "Sound of Music - Closed Organ Pipe" is a type of musical instrument that produces sound through the vibration of air inside a closed pipe. It is commonly used in pipe organs and is known for its rich and resonant sound.
2. How does the "Sound of Music - Closed Organ Pipe" produce sound?
The "Sound of Music - Closed Organ Pipe" produces sound through the vibration of air inside the pipe. When air is forced into the pipe through a valve, it causes the air inside to vibrate at a specific frequency, producing a musical tone.
3. What materials are used to make a "Sound of Music - Closed Organ Pipe"?
The materials used to make a "Sound of Music - Closed Organ Pipe" vary, but they typically include metal, wood, or plastic. The type of material used can affect the tone and quality of the sound produced.
4. What makes the "Sound of Music - Closed Organ Pipe" different from other types of organs?
The main difference between the "Sound of Music - Closed Organ Pipe" and other types of organs is the closed pipe design. Unlike open pipes, which have an opening at the top, closed pipes have a sealed end, creating a more focused and resonant sound.
5. Can the "Sound of Music - Closed Organ Pipe" be tuned?
Yes, the "Sound of Music - Closed Organ Pipe" can be tuned by adjusting the length and diameter of the pipe. This can be done manually or with the use of a tuning device to ensure the pipes are producing the correct frequency for each note in a musical scale.
16K
