Selecting SPDT Switch for 24V Supply Voltage
  • Thread starter Thread starter braren
    Switch
Using a 24V supply voltage to power a relay with a 12V DC coil voltage is causing overheating due to overvoltage. The relay's maximum DC voltage rating of 30V applies to the contacts, not the coil, which should only receive 12V. To prevent damage, a relay with a 24V DC coil should be used instead. The discussion also highlights the importance of understanding Ohm's Law to calculate coil current based on resistance and applied voltage. Proper wiring adjustments resolved initial switching issues with the 24V relay.
braren
Hi,
I'm working on a project where I need to use a couple of relays to send an input signal back to the controller. I'm using the 24V supply voltage from the controller to power a spdt switch, but I noticed that if I keep the switch powered for awhile, it gets hot to the touch.
The specs for the switch are...
Product Height 1
DC Coil Voltage 12
Coil Resistance 270
Max Current Rating 5
Max AC Voltage Rating 250
Max DC Voltage Rating 30
Average Bias Current-Max (IIB)(uA) .003
I know that some components will get a little hot when running under normal conditions, but I guess I'm just not sure if I'm overloading the switch. The specs say that the DC Coil Voltage is 12V, but the Max DC voltage is 30V. Does this mean I can put 30V across the coil and be fine? My next step is going to be measuring the current through the coil when operating, but what kind of calculations or otherwise should I do with that? As long as the current is under 5A, I should be good right?
Thanks for the help!
Are you referring to a relay?
If you are, then the coil can only be powered by 12 vdc. The 30 vdc/250 vac is for the switch contact. Your relay is probably getting hot due to overvoltage on the coil.
If you are going to use 24 vdc to power it, get a relay with a 24 vdc coil.
The coil voltage is 12 volts DC and that is the end of it. You are doubling the specified voltage on the coil. The other voltage ratings are for the relay contacts. If you know ohms law you can tell what the coil current should be by the coil resistance spec and the voltage applied to the coil.
Sorry, yeah, I was referring to a relay not a switch, I have this bad habit of using the words interchangeably :P
The reason I was testing this relay with my system was because when I first wired everything up, I had a 24V relay that, although wired correctly, would not switch over when I applied a voltage to it. I don't know if this is because it was trying to pull more current than was available or what, but I changed some wiring in my circuit (jumpered the supply voltage for the digital Input and outputs together) and swapped the 24V relay back in, and now it's working!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
