Specific Heat Capacity and Change in Internal Energy
The discussion revolves around two physics problems involving specific heat capacity and internal energy changes. The first problem requires calculating the mass of remaining ice after adding it to tea, considering energy exchanges as the tea cools and the ice melts. The second problem involves determining the final internal energy of a gas after performing work and receiving heat, with calculations based on gravitational potential energy and heat transfer. Participants emphasize the need to apply both latent heat for melting ice and specific heat for warming the resulting water. Understanding these concepts is crucial for solving the problems accurately.
nellydude88
I'm having trouble with the following two problems:
1. A jar of tea is placed in the sunlight until it reaches an equilibrium temperature of 32*C. In an attempt to cool the liquid, which has a mass of .180kg, .112 kg of ice at 0*C is added. At the time at which the temperature of the tea (and melted ice) is 15*C, determine the mass of the remaining ice in the jar. Assume the Specific heat capacity of the tea to be that of pure liquid water.
2. The heaviest snake ever found had a mass of 227 kg and measured 8.45 m in length. Suppose a sample of a gas with an initial internal energy of 42.0 kJ performs an amount of work equal to that needed to lift the snake to a height equal to its length. If 4.00 kJ of energy is transferred to the gas by heat during the lifting process, what will be the final internal energy of the gas?
1. C[p,t] * M [t] * (T[f]-T) = C[p,i] * M * (T[f]-T)
Specific Heat of Water = 4.186 x 10 ^ 3.
Specific Heat of Ice = 2.09 x 10 ^ 3
2. PE + KE + U = 0
PE = m*g*h
KE = .5m * V ^ 2
1. (4.186 * 10 ^3) (.180kg) (17) = (2.09 x 10 ^ 3)(.112kg)(15)
I am unaware of how to account for the melted and remaining ice.
Do i just do like a mass initial and final?
2. (227 kg) * (8.45 m) * (9.81) = 18, 817 J I really don't think I am anywhere close to the right answer.
Your help is greatly appreciated.
When the tea cools from its initial temperature to 15C, how much energy is released? How much ice can be melted and then warmed to 15C by that amount of energy?
The gas (a) does some work and (b) has heat flow into it. What's the net change in internal energy? What's the final internal energy?
Would i be using the latent heat equation to figure this out? Q = mL? And if so would i use the latent heat of water? or would i use the specific heat cpacity equation? C[p] = energy transferred as heat/ (mass* change in temperature)
You'll need to use both. The ice first needs to be melted (latent heat of fusion) and then the resulting water needs to be heated (specific heat of water).
You'll to set up an equation and solve for the unknown mass of ice that melts.
