Specific Heat of CO2 and Methane Combustion
The discussion revolves around the specific heat of carbon dioxide (CO2) and the energy of combustion of methane (CH4), focusing on the calculations needed to determine the amount of methane required to raise the temperature of a liter of CO2 from 273.15 K to 573.15 K in an ideal, isolated system without heat losses.
  • One participant estimates that to raise the temperature of 1 liter of CO2, 0.0000096 kg of CH4 is needed based on specific heat and energy of combustion calculations.
  • Another participant corrects the energy of combustion of CH4 from 50.1 KJ/Kg to 50.1 MJ/Kg.
  • Some participants note that the combustion of CH4 produces CO2, which complicates the system, as oxygen is also required for combustion.
  • One participant emphasizes the assumption of an ideal isolated system where heat is transferred directly to CO2 without losses.
  • Concerns are raised about the need to account for additional CO2 produced during combustion and the energy required to heat that CO2.
  • Another participant clarifies that the proposed system is hypothetical, with no contact between methane and CO2, and no other variables considered.
Participants express differing views on the assumptions of the system, particularly regarding the ideal conditions and the implications of combustion products. There is no consensus on the validity of the initial estimation or the implications of the combustion process.
The discussion includes assumptions about an ideal system, potential heat losses, and the effects of combustion byproducts, which remain unresolved.
Kasper_NYC
Hi,
Could you please confirm these estimations for me:
Knowing that the Energy of Combustion of CH4 is 50.1 KJ/Kg, and that the specific heat for the CO2 at 273.15 K is approximately 0.81 KJ/Kg*K; please, could you confirm that in order to increase the temperature of 1 liter of gas of CO2 at 273.15K and 100 KPa (density = 1.98 Kg/m^3, so 0.00198 Kg), from 273.15 K to 573.15 K, it is only needed to combust 0,0000096 Kg of CH4. It is supposed an ideal / isolated system, without heat looses.
Q = m * c * AT
Q = 0.00198 * 0.81 * 300 = 0.481 KJ
Then: 0.481 / 50.1 * 10^3 = 9.6 * 10^-6 Kg, approximately just 0.015 liter.
It seems to be a very little portion of CH4 to me.
Thanks for your help.
PS – I apologize for my English, I am learning it.
I did a mistake... the Energy of Combustion of CH4 is 50.1 MJ/Kg instead "KJ/Kg".
Thanks.
Kasper_NYC said:
Hi,
Q = m * c * AT
One slight complication is due to the fact that carbon dioxide is produced with the combustion of the methane.
Thanks GCT for your answer, but CH4 can’t combust with CO2, so it will need for example Oxygen as well in the system; and in the problem I supposed a hypothetical isolated system, where the heat from the CH4 combustion would be transferred to the CO2 without losses; because that, the only one mass indicate in the formula it was the relative to the liter of CO2.
Thanks again for your answer.
Methane requires oxygen for combustion and carbon dioxide is a direct byproduct of this combustion process ; in order for a more accurate reading you need the specific heat of a calorimetric system.
GCT,
Also the combustion of CH4 in a poor oxygen atmosphere could give Carbon Monoxide and Water… and the reading of the combustion could be a lot more complicate with so many other index if needed, but that wasn’t the case. Just I wanted to confirm the estimation that I posted.
Thanks again.
I think that GCT was referring to the fact that the calorimeter will have a slightly greater amount of CO2 than 1L. The energy of combustion you used only accounts for the energy released during the combustion process of methane + oxygen (both at standard conditions,T=273.15K) and producing some amount of CO2 (also at standard state, T=273.15K). You need to account for the energy required to heat the additional CO2 generated from the combustion process from standard conditions to 573.15 K as well.
It is probably just a minor point.
Chemisttree and GCT,
Thanks again for your answers, but I think there is a misunderstanding in all this, because I didn’t explain completely my proposal. The system that I suggested was supposed to be “ideal and isolated, without heat losses”. So, what I wanted to suggest was a system where the CO2 would receive the heat directly from the Methane combustion, without considering any other variable.
It was like the CO2 was in a hypothetical / special container, that would receive directly the heat from the Methane combustion; but being the methane and the CO2 separated, without any contact between them… so the atmospherics conditions, the sub-products of the methane combustion, as any other index or variable would not account in the problem.
What I wanted to confirm it was just that the combustion of such a little amount of Methane could increase 300 degrees 1 liter of CO2, in an ideal system.
Thanks!
20K
13K
9K
