Specific & Latent Heat - Heat required to turn water in Aluminum Tray -> Ice
The forum discussion centers on calculating the total heat (Q) required to convert 200 g of water at 18°C into ice at -15°C using an aluminum tray weighing 340 g. The calculations involve specific heat and latent heat equations, specifically Q = mcΔT for temperature changes and Q = mLf for phase changes. The final computed value for QNET is 35.1324 kJ, but discrepancies arise as some participants report different results, indicating potential errors in sign usage or computational steps. The correct latent heat value for water is 333,000 J/kg, which must be applied correctly in the calculations.
  • Understanding of specific heat capacity and latent heat concepts
  • Familiarity with the equations Q = mcΔT and Q = mLf
  • Basic knowledge of thermodynamics and heat transfer
  • Ability to perform unit conversions (e.g., kJ to J)
  • Review the principles of thermodynamics related to heat transfer
  • Practice calculations involving specific heat and latent heat with different substances
  • Learn about the significance of sign conventions in thermodynamic equations
  • Explore advanced topics in heat transfer, such as conduction and convection
Students studying thermodynamics, physics educators, and anyone involved in heat transfer calculations or related engineering fields.
format1998
Specific & Latent Heat - Heat required to turn water in Aluminum Tray --> Ice
200 g Water (l) is contained in an Aluminum ice tray that has a mass of 340 g. Both is at 18°C. How much heat (Q) must be removed to turn the water into ice at -15°C?
Aluminum mAl= 340g
Water mW= 200g
Ti= 18°C
Tf= -15°C
Specific Heat Q = mcΔT
Latent Heat Q = mLf
QNET= heat removed to bring Aluminum from 18°C to -15°C
+ heat removed to bring Waterl from 18°C to 0°C
+ heat removed from water to change phase (liquid to solid)
+ heat removed to bring ice from 0°C to -15°C
QNET = (mcΔT)Al + (mcΔT)W(l) + (mLf)w + (mcΔT)W(s)
QNET = [.34kg (900 \frac{J}{kg*°C})(-15°C-18°C)] + [.2kg (4186 \frac{J}{kg*°C})(0°C - 18°C)] +[.2kg (333*103 \frac{J}{kg})] + [.2kg (2100 \frac{J}{kg*°C}) (-15°C-0°C)
QNET = 35132.4 J = 35.1324 kJ
My answer is not one of the choices. What am I doing wrong? Please help!
Thank you in advance. Any and all help is much appreciated!
when I did it I got 97.9kJ. I can only imagine that something went wrong with all the - signs.
For the Al I used temp change = 33 (18 to -15), for the water 18 and for the ice 15.
I think you might omit 103 from the latent heat.
ehild
Latent Heat as given on the table was 333 kJ/kg. I needed it to be J/kg, which came out to be 333*103 J/kg.
There is certainly nothing wrong with your method (as far as I can see) it must be a computational error somewhere.
"For the Al I used temp change = 33 (18 to -15)"
Q = mcΔT
33 grams for the mass of the Aluminum tray?
QAl= (.34 kg) (900 \frac{J}{kg*C°})(-15°C - 18°C)
did I lay that out wrong or did I use the wrong numbers?
"for the water 18"
Water in liquid form is from 18°C to 0°C
"ice 15"
Ice from 0°C to -15°C
is that what you meant?
Q(aluminum) = -10098 J
Q (water from 18°C to 0°C) = - 150696 J
Q (water to ice phase change) = 666000 J
Q (ice from 0°C to -15°C) = -6300 J
(-10098 J) + (-150696 J) + (666000 J) + (-6300 J) = 35,132.4 J = 35.13 kJ
What am I doing wrong? Are the signs wrong?
The latent heat has to be taken with negative sign. It is also removed heat. Change + to minus.
ehild
my values are
Q for aluminium =0.34 x 900 x 33 = 10098 J
Q water 18 to 0 = 0.2 x 4186 x 18 = 15070 J
Q water to ice = 0.2 x 333000 = 66600 J I think this is the difference!
Q ice to -15 = 0.2 x 2100 x 15 = 6300 J
These all add up to 10098 + 15070 +66600 +6300 = 98068 or 98kJ
We must be getting close ! I want to go to bed soon
Thank you both for your help! Much appreciated!
  • · Replies 17 ·
