Speed of a Proton in An Electric Field
A user sought help with a physics homework problem involving the speed of a proton in a uniform electric field of 2.35E+3 N/C. They initially calculated the final speed incorrectly due to using the wrong electric field value. After reviewing their work, they corrected the error and found the correct final speed to be 4.05E+4 m/s. The discussion highlights the importance of accuracy in calculations and the collaborative nature of online learning. The user expressed gratitude for the assistance received and indicated they may return for further help in the future.
servb0t
Hello,
First time posting, so I apologize in advance for anything wacky or off. Basically, I'm doing an online homework assignment for my class. Haven't taken physics in three years (hooray high school!), so I'm a bit rusty.
I've laid out the math pretty much exactly how I've attempted it in my notebook, as I believe that my error(s) are not based in the equations I've used.
If any of you wiz kids could kindly look this over and gently guide me in the right direction, I'm sure I'll be able to figure it out. Thanks in advance!1)
A uniform electric field has a magnitude of 2.35E+3 N/C. In a vacuum, a proton begins with a speed of 2.55E+4 m/s and moves in the direction of this field. Find the speed of the proton after it has moved a distance of 2.20 mm.
2)
Force=(Proton Charge)*(Efield)
F=ma
(Vf)^2=(Vi)^2 + 2ax
3)
F= (+1.6e-19 C)*(2.53e3 N/C)= 4.048e-16 N
F=(mass of proton)*(acceleration of proton)
(4.048e-16 N) = (1.673e-27kg)*(a)
(a) = (4.048e-16 N) / (1.673e-27 kg)
a = 2.424e11 m/s/s
(Vf)^2 = (Vi)^2 + 2ax
(Vf)^2 = (2.55e4 m/s)^2 + 2(2.424e11 m/s/s)(2.2e-3 m)
(Vf)^2 = (6.5e8) + 2(5.3e8)
(Vf)^2 = (6.5e8) + (1.065e9)
(Vf)^2 = 1.72e9 m/s
(Vf)= sqrt(1.72e9 m/s)
(Vf) = 41,413.16 m/s
Bah, looking over what I wrote in the thread, it's very apparent that I used E= 2.53e3 N/C instead of E=2.35e3 N/C in the calculations. I revised my math and got the right answer (4.05e4 m/s.)
I'm sure I'll be here more in the future though, thanks for anyone who cared to read :)
/thread
