How Did Galileo's Lantern Experiment Attempt to Measure the Speed of Light?
Galileo's lantern experiment aimed to measure the speed of light by timing the interval between opening a lantern and seeing the light return from an assistant's lantern. The challenge involves calculating the distance, d, needed to ensure that human reaction time (0.2 seconds) introduces no more than an 18% error in the speed of light. The measured speed of light (c_m) is calculated as d/t, where t includes the reaction time, while the actual speed (c) is determined by d/(t - t_r). To maintain an acceptable error margin, the condition c_m must be at least 82% of the actual speed of light. Correctly applying these relationships will yield the required distance, d.
Flyfishinva
I'm having trouble with a proble I'm trying to complete. The Problem states:
Galileo attempted to measure the speed of light by measuring the time elapsed between his opening a lantern and his seeing the light return from his assistant's lantern. The experiment is illustrated in Figure 25-24. What distance, d, must separate Galileo and his assistant in order for the human reaction time, t = 0.2 s, to introduce no more than a 18% error in the speed of light?
The only way I can think to do the problem is with, time = distance/speed of light. Time would equal 0.1 s and speed of light minus 18% error (I think its minus, because the error would make the velocity seem slower) would be 2.46E8 m/s. d= 0.1s(2.46E8 m/s) = 2.46E7 m (the wrong answer). Any suggestions? Thanks
The measured speed would be c_{m} = d/t where t = total elapsed time which includes the reaction time of .2 sec.
The actual speed of the light would be c = d/(t-t_r)
So the question asks: what value of d will make the difference c-c_m less than or equal to .18c? That means that c_m \ge .82c.
Use the relationship: t - t_r = d/c and t = d/c + t_r
AM
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
