- #36
PeterDonis
Mentor
- 45,651
- 22,668
? said:I have searched for a particular reference I remember from this website about different accelerations at the ends of an accelerating rod, but have not found it.
I think you are talking about this page from the Usenet Physics FAQ:
http://math.ucr.edu/home/baez/physics/Relativity/SR/spaceship_puzzle.html
I'm not disputing anything about how the Bell Spaceship Paradox works, nor am I saying that either version (the one described in the web page, or the "modified" one that you describe) is physically impossible. They're both physically possible; they're just different, and since the wording of your formulation of the scenario was ambiguous, I couldn't be sure which "version" of the scenario you intended. Your follow-up remarks make it clear that you intended the "modified" version, where the two ships remain at the same distance apart as seen by each other (the Usenet Physics FAQ page calls this the "second picture"). That's fine, as long as you bear in mind the observations I raised in post #32 about this version of the scenario.
? said:You state that it is logically impossible for the ends of an infinitely stiff object to have different accelerations, but relativity is often not logical.
That's not what I said. I said that it is logically impossible for the two ends to have different accelerations *and* remain at the same distance from each other *as seen in the original inertial frame*. That's true. And relativity *is* always logical; it's a consistent mathematical system. It's just not always based on intuitively obvious premises.
? said:It is mathematically imperative that the two ends of the object have different accelerations if they are to have the same velocity during the acceleration.
Now you're getting ambiguous again. Velocity relative to what? I *think* you mean "velocity relative to the MCIF at any given event along the accelerating observer's worldline", but if so, you should state that explicitly instead of assuming that "velocity" unqualified has a well-defined meaning.
? said:If you calculate the original Bell Paradox, obviously the two ships will keep getting farther apart as each ship views the other. If they keep the same distance apart in the stationary reference frame, then they must get farther apart as each views each other. Length contraction alone guarantees this.
Agreed. This was the point Bell made in his original paper about the paradox. (It's in his book, "Speakable and Unspeakable in Quantum Mechanics", by the way, which I highly recommend.) Again, I wasn't disputing any of this; I was just trying to figure out which version of the scenario you intended.
? said:I do not necessarily like the idea of infinitely stiff objects. You have to keep remembering the "infinitely stiff" assumption as you go through your calculation and keep trying to assess how this assumption is affecting the outcome of your analysis.
Wouldn't it be better to recognize that, since "infinitely stiff" is physically impossible (since it would imply a sound speed greater than the speed of light), you should leave it out of your analysis altogether, and recognize explicitly that to realize the scenario you describe, you need a family of observers executing pre-planned acceleration profiles that are related in a particular way? You can express everything you need to express about this scenario without having to postulate anything at all about hypothetical massless objects linking the various observers. You just need to describe each observer's worldline, and that's easy to do; the page I linked to above writes down the appropriate equations.
? said:But it is useful in some cases; I would even offer that it is incredibly useful as the above example illustrates. The infinitely stiff object will appear stationary simultaneously in any inertial reference frame along its entire length at its original undistorted dimensions, although clock readings down its length will vary as I have indicated.
As I just noted, you can derive all of these consequences without ever postulating the infinitely rigid "framework" at all. A fleet of rocket ships each executing the appropriate pre-planned acceleration profile will work just as well, plus it won't violate any physical laws as the infinitely stiff object does. The scheme of varying the acceleration profile with distance goes by the name of "Born rigid acceleration", and there's a good page about it here:
http://www.mathpages.com/home/kmath422/kmath422.htm
