Calculate Speed of 50-g Bullet Impacting 2-kg Ballistic Pendulum Can
  • Thread starter Thread starter tandoorichicken
    Bullet
The discussion centers on calculating the speed of a 50-g bullet impacting a 2-kg ballistic pendulum can that rises to a height of 1.3 m. It emphasizes the importance of using momentum conservation and energy conservation principles, particularly since the collision is inelastic. The kinetic energy of the bullet before impact is equated to the potential energy of the bullet and can after they rise. The calculations lead to the conclusion that the bullet's speed just before the collision is approximately 207 m/s. This analysis effectively combines momentum and energy equations to solve the problem.
tandoorichicken
A 50-g bullet is shot into the 2-kg can of a ballistic pendulum. The can rises to a height of 1.3m Determine the speed of the bullet just before the collision.
Don't know how to begin.
I know you say that you don't know how to begin, but I'm hoping you see that this is a momentum problem.
IMO momentum problems are best done by drawing a free body diagrams: one immediatly before an event, one immediatly after (or during) an event and one at the end of the event as felt be the whole system (ie a baseball just prior to being hit by a bat, a baseball while (or just after) being hit by the bat, and the final distance traveled by the baseball). Once you have a good set of FBD's analyze the energies at each point of the overall event.
That should get you going.
Since the collision is completely inelastic, momentum is conserved.
Conservation of energy. (You appear to be doing problems from a chapter on "conservation of energy!)
Initially, the bullet with mass 50 g= 0.05 kg has (unknown) speed v. It's kinetic energy is (1/2)(0.05)v2= 0.025v2. Taking the height of the bullet and block at the moment of impact to be 0 potential energy, since the block is not moving, the total energy of bullet and block is the kinetic energy of the bullet: 0.025v2.
The bullet and block together rise to a height 1.3 m above the base height, and have 0 speed there. Their potential energy is (0.05+2)(9.8)(1.3)= 26.117 Joules and is the total energy.
Solve 0.025v2= 26.117.
I think if something hits and sticks, energy is not conserved.
you'd need both momentum and energy equations for this question. letting
Mb = mass of bullet,
M = total mass of can and bullet,
Vb = velocity of bullet just before collision,
V = velocity of bullet+can immediately after collision,
h = height of rise,
we can write 2 equations:
(momentum) MbVb = MV
(energy) (1/2)MV^2 = Mgh
solving for Vb, we get
Vb = MV/Mb
Vb = (M/Mb) sqrt(2gh)
Vb = 2.05/0.05 rt(2x9.81x1.3)
Vb = 207 ms^-1
