Spherical coordinates rewrite help
The discussion centers on converting a continuous function f(x,y,z) into spherical coordinates for integration. The conversion formulas are x = rcos(θ)sin(φ), y = rsin(θ)sin(φ), and z = rcos(φ). The integral to be rewritten is _{\int\int\int}s f(x,y,z)dV, which requires understanding the Jacobian function to determine how dV changes during the transformation. Participants express confusion about the conceptual requirements of the problem, particularly regarding the application of the Jacobian in this context.
  • Understanding of spherical coordinates and their conversion formulas
  • Familiarity with multivariable calculus and triple integrals
  • Knowledge of the Jacobian determinant and its application in variable transformations
  • Basic integration techniques in three-dimensional space
  • Study the Jacobian function and its role in changing variables in integrals
  • Learn how to derive the volume element dV in spherical coordinates
  • Practice rewriting integrals in spherical coordinates with various functions
  • Explore applications of spherical coordinates in physics and engineering problems
Students in multivariable calculus, educators teaching integration techniques, and anyone needing to apply spherical coordinates in mathematical problems.
Jbright1406
Let f(x,y,z) be a continuous function. To rewrite f(x,y,z) as a function of spherical coordinates, the conversion x-rcos(\theta), y=rsin(\theta), and z=rcos(\varphi). Suppose S is a region in 3 dimensions. How would you rewrite _{\int\int\int}s f(x,y,z)dV as the integral of a function in terms or r,\theta, and\varphi
Note the s by the integral should be a subscript
Hint, may require a change of variable formula
3. The Attempt at a Solution
I attempted to plug in the conversion of x, y, and z, but i don't think this is what is needed. I believe it is more of a conceptual question. What should i do?, I am comfortable with the integration or deriving of the stuff, but am not sure what he is actually is asking. This isn't a homework problem to turn in, but something we were supposed to look at.
Do you know of a function called the Jacobian function? Because you will need this to find out what dV changes to.
Also I think x=rcosθsinψ y=rsinθsinψ z=rcosψ
no, I've never seen jacobian's. I know the name and have heard them mentioned, but have never seen them
It says home work, buts it on the bottom of a test review, its not something to turn in, i can post the entire test review if you don't believe me, where it says it at the top of the page
here is a copy of the problem in case i typed it wrong
