Spherical electric field of electron.
The discussion centers on the experimental findings regarding the electron's shape and electric field characteristics, highlighting a 2011 Nature article that confirmed the electron's extreme sphericity. Feynman's Lectures mention that the electric field deviates from the expected 1/r^2 behavior near the electron's center, but lack specific experimental references. The conversation also addresses the significance of measuring the electron's electric dipole moment, which is crucial for understanding CP invariance; recent experiments have set limits on this moment, nearly ruling out several theoretical models. Additionally, there are inquiries about the alignment of the electric dipole moment with the electron's spin and the potential for higher-order moments like quadrupole moments. Overall, the discussion emphasizes the complexities of defining the electron's properties beyond its charge and mass.
skybobster
On May 25, 2011, the journal Nature published an article stating that the electron was experimentally found to be extremely spherical. In Volume II, Chapter 5 of Feynman's Lectures on Physics, he states that the electric field of an electron has been experimentally determined to vary significantly from 1/r^2 as one approaches the center, where the field is singular. He gives no reference for this remark. Does anyone know of experimental results which have determined the electric field (or potential) as a function of the radial distance r for an electron (assuming spherical symmetry as a first approximation)?
The experiment you mention is very important, and it's unfortunate that the popular accounts of it make it sound so trivial, that the electron is "very round."
What they did was to attempt to measure the electron's electric dipole moment. A nonzero electric dipole moment would violate CP invariance. In the standard model, the electron does have an electric dipole moment but it is extremely small, about 10-42 e-cm. Most alternative models including supersymmetry and technicolor predict a much larger moment, around 10-29 e-cm.
The present experiment failed to find a moment but pushed the limit down to 10-28 e-cm, almost to the point where some of the leading theories would be eliminated.
Is the electron's electric dipole moment aligned with its spin direction (like the magnetic moment)?
If not, then to fundamentally specify an electron, do you have to specify its momentum, electric dipole moment direction, and spin, respectively:
\psi=\psi_+(p,\theta_{e-d},\phi_{e-d})|+>+\psi_-(p,\theta_{e-d},\phi_{e-d})|->
Also, can an electron have quadrapole moments? Isn't there a limit to the number of possible form factors (since there are a finite combination of gamma matrices), so eventually the electron can't keep on having new features such as extra moments?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
