How Do You Calculate Acceleration and Friction for a Rolling Spherical Shell?
  • Thread starter Thread starter Black_Hole???
    Rotation Spherical
The discussion focuses on calculating the acceleration, friction force, and minimum coefficient of friction for a hollow spherical shell rolling down a slope at an angle of 38 degrees. The initial calculations for acceleration yielded incorrect results, leading to confusion about the sine function's evaluation. The correct approach involves recognizing that the sine of 38 degrees must be calculated in degrees, not radians, which resolves the discrepancies in the acceleration value. The friction force was also miscalculated, but the method using Newton's second law was correctly applied. Ultimately, the key takeaway is the importance of using the correct units when calculating trigonometric functions in physics problems.
Black_Hole???
Q1.) A hollow, spherical shell with mass 1.70 rolls without slipping down a slope angled at 38.0.
-Find the acceleration.
-Find the friction force.
-Find the minimum coefficient of friction needed to prevent slipping.
If it rolls wthout slippng, the increase in Kinetic Energy equals the decrease in Potential Energy. The kinetic energy is in two parts, rotation and translation.
M g H sin 38 = (1/2) M V^2 + (1/2) I (V/R)^2
= [(1/2) + (1/3)] M V^2
The M's and R's cancel and
gH sin 38 = (5/6) V^2
V = sqrt (1.2 g H sin 38) = sqrt (2 a H)
where a is the acceleration
a = 0.6 g sin 38
= 1.74 which is wrong
Use that acceleration and Newton's second law t compute the actual friction force, F.
M g sin 38 - F = M a
Mg sin 38 - M*0.6 g sin 38 = F
F = 0.4 M g sin 38
=1.975 which is wrong
To provide this amount of friction, the static coefficient of friction mu,s must equal or exceed a value given by
M g cos 38 * mu,s = 0.4 M g sin 38
mu,s = 0.4 tan 38
=.124 which is also wrong.
Can someone please check over what i did and see if i miscalculated or something.
a = 0.6 g sin 38
6/5*g*x*sin38 = 2*a*x
a = .6*g*sin38 = .6*9.8*.616 = 3.63 m/s2
ok how does the sin(38) = .616?
i keep getting .296369
It is the right answer though
You're evaluating the sine in units of radians. Switch to degrees (or multiply 38 with pi/180 before evaluating the sine).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
