How Can We Prove that a Curve with Perpendicular Derivative Lies on a Sphere?
  • Thread starter Thread starter sharpstones
    Spherical Vector
A curve with a position vector r(t) that is always perpendicular to its tangent vector r'(t) indicates that the curve maintains a constant length. This is established through the relationship that if the dot product r(t) · r'(t) equals zero, then the derivative of the squared magnitude of r(t) is zero, implying constant distance from the origin. Consequently, the curve must lie on the surface of a sphere centered at the origin. The discussion highlights the challenge of proving this property mathematically, emphasizing the importance of understanding vector derivatives and their geometric implications. The conclusion drawn is that the curve's perpendicularity to its derivative confirms its spherical nature.
sharpstones
My friends and I have been trying to work this one out all night, but to no avail.
If a curve has the property that the position vector r(t) is always perpendicular to the tangent vector r'(t), show that the curve lies on a sphere with center the origin.
We know the dot product of r(t) and r'(t) = 0 or that r(t) cross r'(t) equals the multiplication of their magnitudes but to go about showing that it is a sphere because of this is causing a great deal of difficulty. Any help would be appreciated
If \vec r \cdot \frac {d \vec r}{dt} = 0 then \frac {d}{dt} r^2 = 0.
Or, to put what Tide said in different words, if the derivative of a vector is always perpendicular to the vector, the vector has constant length.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
