Understanding Mass-Spring Behavior in Zero Gravity
In a zero-gravity environment, a spring with an attached mass can still exhibit movement due to the potential energy stored in the spring when it is either stretched or compressed. When the mass is attached without any initial disturbance, the spring remains at its equilibrium position, and no oscillation occurs. However, if the mass is released from a position away from equilibrium, it will oscillate as the spring exerts a restoring force. Observing the energy transformations in the simulation, including kinetic and potential energy, provides further insight into this behavior. Understanding these dynamics clarifies that the spring's movement is not solely dependent on gravitational forces.
aatari
Hi Guys,
So I am using the following simulation for this activity (Mass and Springs).
The concept I need help with is to understand why when attaching a mass, the spring moves downward when the gravity is zero? If there is no gravity my limited understanding is that spring should not move.
Can someone please help me understand this phenomenon.
Thanks!
1. Homework Statement
How can you account for the behaviour of masses on springs when the force of gravity is zero? Give your answer both qualitatively (written explanation) and mathematically (algebraic explanation).
[/B]
Fs = Fg
Fg = mg
Fs = k.x
When I went to the simulation website, it settled back to the dashed line for g=0. When you first hook it on, if you are not exactly on the equilibrium point then there will be some disturbance of the spring - note that you can use the hand to pull on the masses, then release and watch it oscillate.
If the spring is horizontal on a table, and you pull on it, you would expect it to exert a force back toward the equilibrium point.
Likes aatari
If you attach the masses without stretching or compressing the spring, there is no oscillation.
If you attach the mass and release it away from the neutral point, it oscillates because you have provided some potential energy by stretching or compressing the spring.
Likes scottdave and aatari
You guys are awesome. I actually took the spring disturbance as movement and this is obviously not the case. Using the ruler and dash line really helps. Thank you for the clarification.
Try turning on the energy bar graphs to watch how energy changes between different forms (kinetic, gravitational PE (if gravity), spring PE, and thermal (from the friction)). It is interesting to watch how the bar graphs respond.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
