grouchy
- 73
[SOLVED] Spring Collision
A 8 kg block is pushed by an external force against a spring with spring constant 173 N/m until the spring is compressed by 2.1 m from its uncompressed length (x = 0). The block rests on a horizontal plane that has a coefficient of kinetic friction of 0.56. The acceleration of gravity is 9.8 m/s^2. Remember: The block is not attached to the spring.
After all the external forces are removed (so the compressed spring releases the mass) how far D along the plane will the block move before coming to a stop? Answer in units of m.
The attempt at a solution...
Ui - Wf = 1/2mv^2
(0.56)mgd = 1/2kx^2 - 1/2mv^2 then I just moved everything over to get d but I used 1/2kx^2 to get the v by setting it equal to 1/2mv^2 so it just cancels out...
Ui - Wf = 1/2mv^2
