Solving the Mystery of a Frictionless Ramp & Spring
The discussion revolves around a physics problem involving a block falling onto a frictionless ramp and compressing a spring. The key points include the use of gravitational potential energy equating to spring potential energy to find the compression distance, and the confusion about whether the block can return to its original height due to the spring's oscillation. It is clarified that while the spring may oscillate, the conservation of energy principle still holds, allowing the block to reach its initial height if the spring is considered massless. However, if the spring has mass, it would absorb some energy, preventing the block from returning to its starting height. The conversation suggests that using conservation of linear momentum alongside energy conservation could help solve for unknowns in this scenario.
transmini
So this sounds homework question but I promise its not. At least its not mine. I saw it on a website because someone made it funny because of what they answered (drew an elephant if you know the one I'm talking about)
Anyway, so the problem was a block of mass m = 5 kg falls starting at rest at h = 5 m down a curved frictionless ramp into a spring with spring constant k = 100 N/m. Find the distance it compresses x and find the height the block comes back up to.
I understand using gravitational potential energy is equal to spring/elastic potential energy at the max compression to find x, but what I don't quite get is finding the max height the block comes back up to. I'm finding online that its the same as the starting height because all the potential energy in the spring is pushed back into the block and since the ramp is frictionless. But wouldn't the spring still oscillate hinting that it has energy? If it has energy, wouldn't this energy had to have been taken from the kinetic energy of the block? Otherwise how does the spring get the energy to oscillate and still push the block back up to initial height?
The spring's oscillatory motion means that it would have kinetic energy too, but this then implies that it should have mass. The problem is if you consider it to be a massless spring, the differential equation describing this oscillatory motion would become kx = 0, meaning that it doesn't move at all. In a real world scenario, the spring would have mass, and the mass in the spring is what keeps its oscillation going, described by the solution to mx"+kx = 0 when there is no friction, and then the block would indeed not reach its initial height again because energy is transferred to the spring.
That makes sense that its being assumed as massless and that it wouldn't ACTUALLY behave like that. So would the spring be leeching its energy from the kinetic energy of the block then? And while the answer makes sense, is there a way to show without differential equations? I'm just starting my degree and don't do anything with those until this fall.
If the spring had a mass, yes it would be leeching energy from the block, although the correct physical way to say this is to say that the block does work on the spring, reducing its own energy and increasing the energy of the spring. Conservation of energy would still hold if you consider the system being the block + the spring then, as the total energy of the block and spring together would still equal the potential energy of the block at the start. The problem however is that the law of conservation of energy will only allow you to solve for one single unknown, and you cannot thus find the solution using just energy conservation in that case. The energy stored in the spring would be given by E:
m_b g (h_{initial} - h_{final} ) = E
which is therefore a second unknown in that equation. What you can do is use conservation of linear momentum along with conservation of energy, which should allow you to solve for the remaining unknowns.
As for the oscillatory motion of the spring...if you know that the spring has eventually stored an amount of energy equal to E (after the block has separated from the spring), conservation of energy on the spring alone will give you another differential equation:
\frac{kx^2}{2}+\frac{m_s v^2}{2} = E
where v = dx/dt. I can tell you that the solution to this is x(t) = \sqrt{\frac{2E}{k}} \sin(\sqrt{\frac{k}{m_s}} t + \phi) which you can check by doing the differentiation and substitution in the equation above.
EDIT: Also, I'm not sure whether you can show that the spring oscillates without going into differential equations.
It's even harder to consider what would happen in subsequent descents of the mass. It could strike the spring in any phase of itself oscillation and either increase or decrease the spring's oscillatory energy. The problem is in the realm of Coupled Oscillators but the analysis could be a bit hard because of the impulsive situation when the mass hits the spring each time. Including the losses would make things even worse.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
