Max Distance Calculated for Spring Mass System of K=450N/m, m=2.2kg
  • Thread starter Thread starter samdiah
    Mass Spring
A spring with a spring constant of 450 N/m is analyzed with a mass of 2.2 kg attached to it. The net force acting on the mass is calculated to be 21.56 N, leading to a displacement of 0.05 m. The equilibrium position is determined by setting the spring force equal to the weight of the mass, resulting in a distance x below the initial position. The block will fall until the spring force overcomes its momentum, and due to the system's symmetry, the maximum distance fallen before moving upward is twice the equilibrium distance. The discussion clarifies the relationship between the forces and the maximum displacement of the block.
samdiah
A spring with K=450N/m hangs vertically. You attach 202kg block to it and allow the mass to fall. What is the maximum distance the block will fall before it begins moving upward?
ans-
k=450N/m
m=2.2kg
x=?
Fnet=mg
=2.2kg*9.8N/m
=21.56 N
F=+/- kx
x=f/k
x=0.05m
Is this the max distance I calcul;ated or the new equilibrium distance? Can u give me a hint.
The equilibrium position will be where the force equals the weight:
450x= 2.2(9.8), measured below the initial position. Since the mass gains momentum as it falls, it will have its maximum velocity when it passes there, a distance x below it's initial position. It will continue to fall until the spring overcomes that momentum. Because of the symmetry of the situation, that distance below equilibrium will also be x. The "maximum distance the block will fall before it begins moving upward" will be 2x where x satisfies 450x= 2.2(9.8).
HallsofIvy, I don't understand what you are saying.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
