Finding the Mass Required for Double the Velocity in a Spring-Mass System
  • Thread starter Thread starter brenfox
    Spring Velocity
To find the mass required to double the velocity in a spring-mass system, a mass of 0.3 kg is initially suspended from a spring with a stiffness of 200 N/m, resulting in a maximum velocity of 0.26 m/s. The calculated velocity for double the maximum is 0.52 m/s, leading to an initial mass calculation of 0.07 kg based on the spring's stiffness and deflection. However, this result contradicts the expectation that a higher velocity should correspond to a greater mass, highlighting a misunderstanding of the relationship between mass, velocity, and spring force. The discussion emphasizes that while greater mass increases inertia, it does not inherently lead to higher velocity under the same spring conditions and deflection. Clarification is needed on how mass and displacement interact in this context.
brenfox
A mass of 0.3kg is suspended from a spring of stiffness 200Nm. If the mass is displaced by 10mm from its equilibrium position and released for the resulting vibration, calculate:
The mass required to produce double the maximum velocity calculated in question 2 using the same spring and deflection. The velocity in question 2 being 0.26ms-1.
V=Aωcos(ωt+∅)
ω=√k/m
So A=0.01 v= 0.52MS-1.
So transposing ωcos = 0.52/0.01 = 52rads.
Now with these numbers i can find the mass.
ω=√k/m
Transposing m = k/m^2
Mass = 0.07kg.
Now the laws of physics are telling me this answer cannot be right. If an object with a mass of 0.3kg possesses a velocity of 0.26ms-1, then an object with a velocity of 0.52ms-1 should be greater than 0.07kg. The velocity is higher so surely the mass must be greater. Where am i going wrong with this!. Any help would be appreciated.
I see no reason why a greater mass should mean a higher velocity. Think about the acceleration. A higher mass has greater inertia, but the same deflection of the same spring only produces the same force.
Maybe you are subconsciously taking the greater mass case also to have a greater displacement as part of a general scaling up. In that case you could get a greater velocity.
Likes 1 person
