Springs, Kinetic Friction, and Distance help me please
A 1.4 kg block is compressed against a spring with a force constant of 740 N/m and is released to slide across a surface, encountering a rough patch with a coefficient of kinetic friction of 0.44. The goal is to find the compression distance d that results in the block achieving a speed of 2.3 m/s after crossing the rough patch. The kinetic energy of the block after passing the rough surface must account for the work done against friction, which reduces its initial energy derived from the spring. The discussion emphasizes understanding the relationship between spring force, kinetic energy, and the effects of friction on motion. Clarification on applicable equations and conceptual understanding is sought to solve the problem effectively.
PhysicsOPhun
Springs, Kinetic Friction, and Distance...help me please
1. In the figure below a 1.4 {\rm kg} block is held at rest against a spring with a force constant k = 740 {\rm N/m}. Initially, the spring is compressed a distance d. When the block is released, it slides across a surface that is frictionless except for a rough patch of width 5.0 {\rm cm} that has a coefficient of kinetic friction mu = 0.44.
2. Questions: Find d such that the block's speed after crossing the rough patch is 2.3 {\rm m/s}. /b]
[PLAIN][PLAIN]http://img84.imageshack.us/img84/1249/111it7.jpg
3. Relevant equations: Ok, I know how to apply the kinetic friction to the mass but how do I start this equation? What effect does the force of the spring have on the velocity and how does the defined distance work out? I really want to understand this but am afraid that conceptually it's hard for me to work out. Any pointers or all applicable equations would greatly be appreciated so I could get on with this. I have been doing Chemistry since 6am and my brain is just not tickin right now...
I apologize if I messed up the template, this is my first post so I will hope to not make any mistakes again if i did this time.
Also, my work as of right now for this problem consists of 2 pages front to back with writing all over, I really wouldn't know where to start and am so confused at this point that I could really use a push.
Starting with 2.3 m/s speed of the block after it passes, compute the kinetic energy of the block.
When the block passed over the rough surface, friction did work against the block, so some energy was lost. Determine the work done on the block. The kinetic energy of the block before it enountered the rough surface must be the sum of the KE after and the work done by friction.
The kinetic energy of the block comes from the energy stored in the spring, which is related to the deflection of the spring and spring constant.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
