Square root and cube root question
The discussion explains that cube roots can be taken from negative numbers because they yield real results, while square roots of negative numbers result in imaginary numbers. A square root is defined as a number that, when multiplied by itself, gives the original number, and every positive number has two square roots. In contrast, a cube root is one of three equal factors of a number, allowing for real results regardless of the sign. This distinction between even and odd roots is emphasized, with even roots yielding nonnegative results and odd roots retaining the sign of the original number. Understanding these principles clarifies why negative numbers behave differently under square and cube roots.
Mejiera
why is it possible to take the cube root of a negative number and not a square root of a negative number?
It is possible to take the square root of a negative number, but you don't get a real number.
If you can write the number whose square root you want as the product of two equal factors, the square root of that number will be one of those factors. For example, 4 = 2*2, so the square root of 4 is 2. Every positive number has two square roots: a positive square root and a negative square root. The symbol \sqrt{n} is taken to mean the principal or positive square root.
The cube root of a number (positive or negative) is one of three equal factors of that number, so \sqrt[3]{27} = 3, since 27 = 3*3*3. Similarly, \sqrt[3]{-8} = -2 since -8 = (-2)(-2)(-2). Real numbers have only 1 real cube root.
HTH
Make an assume that it is possible , and work in reverse.. you will realize something tat contradicts from what you've learnt.
oh I see so for a cube root you a real number answer no matter if its negative or positive ,but for a square root you get an imaginary number if its negative. Mark and icy thanks now I understand.
And the same idea can be extended to odd and even roots. An even root (square root, fourth root, sixth root, etc.) of a nonnegative real number gives you a nonnegative real number. An odd root (cube root, fifth root, etc.) of a real number gives you a real number with the same sign.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
