Standard deviation of V_x of He gas
The discussion revolves around calculating the standard deviation of the velocity component \( v_x \) for helium gas. The initial equation presented relates kinetic energy to the average squared velocity, leading to a calculation of the root mean square speed, which is found to be 786 m/s. There is clarification on the correct formulation of the variance and standard deviation, emphasizing that \( \sigma^2_{v_x} = <v_x^2> - <v_x>^2 \) and that the average velocity \( <v_x> \) is zero. The participants confirm that the standard deviation equals the root mean square speed, indicating a correct understanding of the statistical relationships involved.
Pushoam
## \frac 1 2 m<v_x^2> =\frac 1 2 k_BT ,
\\ \sqrt{ <v_x^2>} = 556~ m/s ## So, I guess that the standard deviation should be less than rms speed.
So, the option is (a)
## \left< ax + b \right> = a\left<x\right> + b ##
So, ## \left< v_x^2 - <v_x^2> \right> = \left< v_x^2\right> - \left< v_x^2\right> = 0 ##
Is this correct?
[/B]
I think it your last statement, you are attempting to write ## \sigma^2=E(X^2)-(EX)^2 ##. If that is the case, and you are saying ## EX=0 ## , yes, it is correct. Please put in the mass and temperature so that we can check your arithmetic. For the final answer, the standard deviation, ## \sigma_{v_x}=\sqrt{E(v_x)^2}=v_{x \, rms} ##. Also, the statement of the problem is incomplete. The available answers did not show up.
The question is not showing in the OP. So, posting it again.
I didn't understand what you mean by the above line. Please explain the symbol EX and so on.
In probability theory, the ## E ## means expectancy. ## EX ## is the same thing as ## <X> ##.
In the above statement, as ## < v_x ^2> ## is constant, I am taking it out of ## \left< v_x^2 - <v_x^2> \right>## and hence I got ## \left< v_x^2 - <v_x^2> \right> = \left< v_x^2\right> - \left< v_x^2\right> = 0 ##.
But, this way I will always get 0 standard deviation. So, something is wrong with it. Right?
The equation correctly reads ## \sigma^2_{v_x}=<v_x^2>-<v_x>^2 ##. ## \\ ## Editing: This comes from ## \sigma^2_{v_x}=<(v_x-<v_x>)^2> ##. And I think your arithmetic in the OP is incorrect.
Likes Pushoam
## \sqrt{ <v_x^2>} = \sqrt{ \frac { k_BT = 4.14 * 10^{-21}}{m=4* m_p = 6.69 * 10^{-27}}}= 786~ m/s ##
Is this correct?
Likes Charles Link
Yes. Very good. Round that off and (d) becomes the correct answer. See also my edited additions to post 6.
Likes Pushoam
I reloaded the page three times. Still, no edition to post #6 is shown.
What I get in post # 6 is:
Charles Link said:
The equation correctly reads ## \sigma^2_{v_x}=<v_x^2>-<v_x>^2 ##. This comes from ## \sigma^2_{v_x}=<(v_x-<v_x>)^2> ##. And I think your arithmetic in the OP is incorrect.
I didn't use the word "edit". Let me put it in there for clarity. After I wrote the original post, I came back a couple of minutes later and added the last two sentences.
Likes Pushoam
Thanks.
Likes Charles Link
Now I understood.
## \sigma_{v_x} = \sqrt{ \left< (v_x - \left <v_x \right >)^2 \right> = \left < v_x^2 \right > – 2 \left < v_x \right >^2 + \left < v_x \right >^2 = \left < v_x^2 \right > – \left < v_x \right >^2 }##
Since , ## \left < v_x \right > = 0 ##
## \sigma_{v_x} = v_{rms} ##
Likes Charles Link
Very good. :) (You need a parenthesis { } around v_x in the subscript of ## \sigma_{v_x} ##. Then your Latex will work.)
Likes Pushoam
