What Is the Linear Density of the String in a Standing Wave System?
The discussion revolves around calculating the linear density of a string in a standing wave system, where two specific masses (3503.5 g and 2574.0 g) create standing waves at a fixed frequency of 142 Hz. Participants express confusion about how different tensions from the two masses might affect the linear density, questioning whether multiple linear densities could exist. The solution approach involves using the relationship between frequency, wavelength, and tension to derive equations for each mass, ultimately leading to a quadratic equation for the number of loops. Clarification is sought on selecting the correct number of loops from the quadratic results. The thread concludes with a participant realizing a mistake in their calculations, indicating progress in understanding the problem.
Puchinita5
In Fig. below, a string, tied to a sinusoidal oscillator at P and running over a support at Q, is stretched by a block of mass m.The separation L between P and Q is 2.30 m, and the frequency f of the oscillator is fixed at 142 Hz. The amplitude of the motion at P is small enough for that point to be considered a node. A node also exists at Q. A standing wave appears when the mass of the hanging block is 3503.5 g or 2574.0 g, but not for any intermediate mass. What is the linear density (in g/m) of the string?
image: http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c16/pict_16_60.gif
i'm confused because if two masses can make a standing wave, that would suggest two different tensions as well... and wouldn't this also suggest two different linear desnities?? i have no idea how to go about this problem...
if i were to guess, i would use f=v/wavelength to get v...but i don't know if I could assume the wavelength because the way the figure is drawn...because in the figure, the wavelength is obvious, but maybe the figure is just an example and not actually representative of what's happening...but if I do use the figure, then i can solve for v...then with v=(T/u)^.5...where T is tension and u is linear density, then i can solve for desnity, except I have two tensions to pick from...
other than that I'm lost...any help?
If there are n loops in the standing wave, then L = n*λ/2. Or λ = 2L/n.
So v = f*λ = f*2L/n = ( T/μ )^0.5
Write two equations, one for T = 3503.5 g and other for 2574 g for the number of loops n and n + 1 respectively. Solve for n. Substitute it in one of the equations to find the linear density.
okay, solving for N, doesn't that give you two results for N because i ended up with a quadratic equation, how do you know which N to use?
oh wait nevermind, i did something silly
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
