Static air pressure for flying
The discussion centers on the research of wind pressure and its applications in achieving flight through different methods, including hot air balloons, airplanes, and human-powered flight. Hot air balloons rely on buoyancy for elevation, while airplanes operate under the principles of thrust, drag, lift, and weight. Human flight, particularly with technology, faces challenges as gravity predominates, limiting upward movement and requiring propulsion for lateral motion. Skydivers typically use parachutes to manage descent, as freefall leads to terminal velocity where downward drag equals weight. Gliders utilize updrafts to gain altitude, converting forward speed into lift without thrust.
Sknk1999
I am doing a research project about wind pressure and the different uses one can achieve by changing the pressure, volume and speed. I am comparing a hot air balloon ride vs an air plane vs human flight. I am looking and what minimum and maximum MPH is needed to achieve human flight and with what CFM and what Staic air pressure. I really hope someone can spread light on this information.
Hot air baloon achieves elevation due to bouyancy.
An airplane has forces acting upon it that can be simplified as thrust, drag, lift, weight.
Same thing I suppose for human flight, if you are inquiring about using technology to aid a human to achieve flight using his own muscle power for propulsion.
A human, himself though, in air acts somewhat like brick, with the force of gravity being the most predominate, except at terminal velocity when weight and downward air drag are equal. Some manoeuvres with the limbs are possible to adjust lateral motion, but still the only direction to go is down. Most sky divers will use a parachute to slow descent to acceptable levels - the ones without a parachute do not care much for their pancake form afterwards.
A glider has no thrust, so to achieve elevation it rides on the updraft of air currents. It then exchanges altitude forward speed to have air flow over the wings for lift.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
