Static Equilibrium - trick question?
The discussion revolves around a physics problem involving a man standing on a board supported by two cables with different tensions. The initial assumption is that the man's weight is simply the sum of the cable tensions, leading to a weight of 500N. However, confusion arises regarding the use of torque and the position of the man on the board. Participants clarify that since no angles are provided, the cables can be assumed vertical, simplifying the problem. The overall sentiment is that the question is designed to mislead by following more complex problems with a straightforward solution.
prettydumbguy
A man stands on a board of negligible mass with a length of 10m is supported by 2 cables, one on the left on one on the right, with a tension of 300N and 200N respectively. How much does the man weigh in Newtons?
F=ma
Torque= F*lever arm
I'm tempted to just 500, but that's far to simple. I thought of setting up a torque equation, but I don't know how I would when I don't know his mass or where he stands. So, if I assume he's standing x meters from the left: 300(x)-200(10-x) + man(mans location) = 0.
So I set one of the cables as the axis of rotation: the left cable, giving me man(x)=200(10).
Multiply out to get man(x) = 2000.
Now I have two variables I can't get rid of.
But I still really want to just sum all the forces along the y-axis and set it equal to zero: 300 + 200 -man = 0, so I still get 500.
Am I just overthinking the hell out of this?
Assuming the cables are vertical, yes, you're overthinking it. It is as easy as it seems.
No angles were given, so I assume that they are vertical. The question comes after two much more in depth SE problems, hence my confusion. Thanks!
Sounds like a classic way to catch people out, follow some tough questions by an easy one with redundant information.
There's an old geometry problem where you ask someone to cut an L shape, consisting of three squares, into four identical pieces. When they've solved it, you say ok, try this harder one: cut a square into five identical pieces.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
