Analysis of Wall Crane: Force & Moment at Pins A & D
The discussion focuses on analyzing the forces and moments at pins A and D of a wall crane supporting an 800 N load. Participants are attempting to determine the horizontal and vertical reaction components at the pins and the force in the cable at the winch. Initial calculations suggest the tension in the cable is 400 N, leading to a tension in rod BD of 490 N, but discrepancies arise when calculating TBD using moments at pin A, yielding a result of 2752 N. Suggestions are made to clarify the calculations by showing detailed work, particularly in substituting values for the tension. The conversation emphasizes the importance of equilibrium and correct moment calculations in solving the problem.
Harmony
The wall crane in Fig. 3 supports a load of 800 N. Determine the horizontal and vertical
components of reaction at the pins A and D. Also, what is the force in the cable at the winch
W?
[URL=http://imageshack.us][PLAIN]http://img182.imageshack.us/img182/992/tutorialse0.jpg[/URL] http://g.imageshack.us/g.php?h=182&i=tutorialse0.jpg [/PLAIN]
Newton's Laws of Motion, Moment, Equilibrium of Forces
First I draw a free body diagram at B. The vertical forces involved are the y component of the tension in rod BD and the y component of the tension of cable WB.
Since the tension of a massless cable is the same throughout the string, the tension of the cable is 400N. Substituting the value of TWB to the above equation, I get TBD=490N.
However, a problem occurs when I attempt to find TBD by taking the moment at A. The solution for TBD turns out to be 2752N.
What cause the difference in the answer?
I think it will be easier for us to see where you went wrong if you would show some work with regard to the step on substituting the value of Twb.
My suggestion to get Tbd, now that you have the tension in the rope right is to take the moments at A. The sum of moments must be zero. You have a 800N weight acting at 2 meters CW, and Tbw acting at 1 meter at a 60 degree angle CW. The counter moment CCW then must be Dx.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
