Solving a Uniform Beam Inclined at an Angle
A uniform beam inclined at an angle θ is analyzed for stability when a mass M is suspended from its upper end, which is tied to a wall with a rough rope. The problem requires finding expressions for the maximum mass M before the beam slips, the reaction force R at the floor, and the force F exerted by the beam on the rope. Key considerations include the coefficient of static friction μs between the beam and the floor, which is less than the cotangent of θ. The discussion highlights the need to identify the forces acting on the system, including vertical and horizontal components. Understanding these forces is crucial for solving the problem effectively.
doneky
A uniform beam of mass m is inclined at an angle θ to the horizontal. Its upper end (point P) produces a 90° bend in a very rough rope tied to a wall, and its lower end rests on a rough floor (see figure below). Let μs represent the coefficient of static friction between beam and floor. Assume μs is less than the cotangent of θ.
(a) Find an expression for the maximum mass M that can be suspended from the top before the beam slips. (Use any variable or symbol stated above along with the following as necessary: g.)
(b) Determine the magnitude of the reaction force (R) at the floor in terms of m, M, g, and μs.
(c) Determine the magnitude of the force (F) exerted by the beam on the rope at P in terms of m, M, g, and μs.
Net torque = 0
Fnet = 0
I have no clue where to start. Previous ones were easier, I just need to get started.
1. There are two weights that need to be kept static by vertically upwards forces. Where can those forces be applied to the system (or rope, weight and beam) by immovable objects (walls and/or floors)?
2. What is the vertical component of the force with which the beam pushes on the floor?
3. What is the horizontal component of the force with which the beam pushes on the floor?
