Statics Two objects with 3 angles
  • Thread starter Thread starter SLC2SMU
    Angles Statics
The discussion centers on a physics problem involving two cars connected by a cable, with specific weights and angles from the normal. The participant has created a free body diagram and established equations for force equilibrium in both the x and y directions. There is confusion regarding the reference for the angles and the distinction between mass and weight. Suggestions include drawing separate free body diagrams for each vehicle and ensuring all forces are accounted for to solve the problem effectively. The conversation emphasizes the importance of clarity in diagrams and equations for accurate analysis.
SLC2SMU
Ok, Let's see, this problem consists of two (2) cars with a cable of unknown tension between them.
The first car has a weight of 2100Kg and is at an angle of 10 degrees from the normal.
The second car weighs 1360Kg and is at an angle of 26 degrees from the normal.
There is a rope connecting them at an angle of 18 degrees from the normal.
W=mg
Fx=0
Fy=0
So far I have drawn a free body diagram that seems to be accurate. I have then divided the variables up into their respective coordinates
Fx=0=Tcos(18)-N1cos(10)-N2cos(26)
Fy=0=N1sin(10)+N2sin(26)+ Tsin(18)-M1g-M2g
I have been tinkering around with this and have been unable to come up with anything. I think that possibly the first car does not matter and only the second car matters because it is the weight and I can assume car 1 is fixed. If not that then possibly doing variable subsitution?
Any Ideas?
You speak of angles "from the normal" but you don't say what your reference is, what is this normal perpendicular to?
By the way, if the unit is kg, then the quantity is a mass, not a weight. If it is a weight, it will be in Newtons.
It would probably be a very good idea to post a figure for this problem. Also, you might want to try drawing (and posting) a FBD for each body.
Ok let me try and get it uploaded.
Ok here is the file, I couldn't just get the picture so I had to put up the entire file. It is problem 3.16. for my FBD I have a N1 and N2 perpendicular to each of the vechicles and a force of Mg straight down. and a force of -T from the truck and a force of T from the car. I don't have a scanner otherwise I would upload the FBD.
I think the file is on this one.
Looks like you need two FBDs, one for the crane and for the caisson. That should give you six equations, two translations and one rotation for each body. You have a little bit more work to do.
