Statistics- unbiased estimator #2
  • Thread starter Thread starter Roni1985
    Statistics
The discussion revolves around finding an unbiased estimator for the parameter \(\Theta\) based on a random sample from a given probability density function (pdf) that resembles an exponential distribution. The original poster expresses uncertainty about their solution involving the minimum of the sample, \(Y_{\min}\), and its expected value.
  • Participants discuss the derivation of the pdf for \(Y_{\min}\) and its relationship to the original distribution. There are questions about the correctness of the equations used and the logic behind deriving the pdf and cumulative distribution function (CDF) for \(Y_{\min}\). Some participants express confusion regarding the calculations and assumptions made in the process.
The conversation is ongoing, with participants providing insights into the derivation of the distributions involved. Some guidance has been offered regarding the correct approach to finding the distribution of \(Y_{\min}\) and its expected value, but there is no explicit consensus on the correctness of the original poster's calculations or assumptions.
Participants note that the original pdf is provided, and there is uncertainty about the derivation of the minimum's distribution. The discussion includes questioning the validity of certain steps in the derivation process and the implications for determining whether the estimator is unbiased.
Roni1985
There is some question, I solved it but am not sure I got the right answer.
Let Y1, Y2... Yn be a random sample of size n from the pdf fY(y;\Theta= \frac{1}{\Theta}*e-y/\Theta , y>0
Let \Theta_hat=n*Ymin is tex]\Theta[/tex]_hat for \Theta ?
Ymin=n*(1-FY(y))n-1fY(y)
Also, it looks like an exponential distribution.
What I need to find is E[n*Ymin]
I get [(-n)/(n+1)]/(1/ \Theta )
Is this the correct answer ?
where did you get the eqn for Ymin it makes no sense.
i take that back give me a sec
okay here it is. the PDF of Ymin is f(y)=(-n/theta)*exp(-yn/theta). To get this we need to use the following (questionable?) sequence of logic: the probability that ymin is less than y is 1 minus the probability that ymin >= x. for this inequality to hold we need Y(i)>=x for all i. i.e. Y(1)>=x AND Y(2)>=x ... Y(n)>=x. this will give us the CDF for Ymin from which we derive the PDF of Ymin given above. Now check that E(nYmin)= theta. (I actually get
-theta but there may be some minor issue with my calculation see what you get, if
E(nYmin) =theta (not negative theta) then it is unbiased.
Hello,
I don't really understand what you are trying to do here.
you found the pdf for Ymin ? we are given the pdf
Also, I got the CDF for Ymin, but am not sure I did it the right way.
And , I don't really understand what you got for the CDF..
Thanks.
You are given the distribution for the individual values - it is the distribution from which you take the sample. The minimum is a statistic, and you need its distribution.
The derivation outlined above is correct. If Y_{\min} is the minimum of a sample, then to get its distribution (assuming the sample comes from a continuous distribution, as yours does). I'll use G, g for the CDF and PDF of Y_{\min}, and F, f for the CDF and PDF of the population.
<br /> P(Y_{\min} \ge t) = P(X_1 \ge t \text{ and } X_2 \ge t \dots \text{ and } X_n \ge t) = (1-F(t))^n <br />
because of independence, so the CDF of Y_{\min} is
<br /> G(t) \equiv P(Y_{\min} \le t) = 1 - (1 - F(t))^n<br />
and the density Y_{\min}is
<br /> g(t) = G&#039;(t) = n(1-F(t))^{n-1} f(t)<br />
In your problem the original data come from an exponential distribution. Use the CDF for that in place of F, the PDF in place of f, to get the density of Y_{min} in this particular case. The expected value of the minimum is
<br /> \int t g(t) \, dt<br />
and this will be a function of \theta. You should be able to finish the problem from there.
