I Stellar reddening via Av calculation
Calculations of stellar reddening via interstellar extinction show discrepancies between personal results and literature values. The calculated Av for Betelgeuse was 1.12 mag and for Deneb, 0.11 mag, which are significantly lower than the 5-10 mag range found in sources. The discussion highlights uncertainty regarding whether the apparent and absolute magnitudes used in calculations account for extinction or are based on actual measurements. The need for clarity on the methodology of these magnitudes is emphasized. Accurate calculations of stellar reddening require careful consideration of extinction factors.
bruha
Hello, please do somebody have some experiences with calculating of stellar reddening via interstellar extinction? I made some calculation based on apparent and absolute magnitudes and distances of brigthtness star but maximum Av which I got for Betelgeuse was 1.12 mag ( for its maximum apparent magnitude since it is variable star) and for Deneb 0.11 mag.
This results are in disagreement with Av presented in literature which reached values at least about 5-10 mag or more ( for example I found some equation Av (mag) = 2*d(kpc) for latitude b to 2 o and Av (mag) = 0.18/sin (b) for b over 10 o...
Thank you very much
Astronomy news on Phys.org
Hello,
thank you. I can say that maybe , here is problem that is not clear if apparent and absolute magnitudes which I found posted on net are these calculated according to equation which neglected extinction or these which was real measured.
Thank you
T.Bruha
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
