Step up transformer + ac generator question
To achieve a peak output of +/- 340V at 50Hz from an AC generator originally designed for +/- 155V at 60Hz, a transformer is required. The transformer equation relates the voltage and number of coils in the primary and secondary circuits. Given the primary coil has 200 loops and the primary voltage is 155V, the secondary voltage must be 340V. The user expresses confusion about how to apply the transformer equation effectively, particularly regarding the frequency of the AC current. Ultimately, using the transformer equation is the correct approach to determine the necessary number of loops in the secondary coil.
tobz102
An AC generator, originally designed to provide a peak output of +/- 155V at frequency 60Hz, is required to provide a peak output of +/- 340V at 50Hz. If the generator is connected to a transformer with 200 loops in its primary coil, how many loops should there be in the secondary coil in order to required the output?
transformer equation? EMF on secondary / EMF on primary = No. coils on secondary / No. coils on primary
I don't understand where to start on this? I know that I need to use the above equation but unsure how to get there
Break it down to what is happening at the primary (input) and secondary (output)
Primary
Voltage =?
No. of coils = ?
Secondary
Voltage =?
No. of coils = ?
Primary
Voltage =?
No. of coils = ?
Secondary
Voltage =?
No. of coils = ?
I was thinking along the lines of:
Primary V=155V
Coils = 200 loops
Secondary V=340V
Coils=?
But surely this is too much of a simple method and also it gets me the frequency of the a.c current...
Primary V=155V
Coils = 200 loops
Secondary V=340V
Coils=?
Well using the transformer equation that is how it should be done.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
