What is the Molar Ratio for Dissolving Aluminum with Sulfuric Acid?
In summary, stoichiometry is the study of the quantitative relationship between reactants and products in a chemical reaction. It is important for predicting and determining the amount of products and reactants in industries such as pharmaceuticals and agriculture. Stoichiometry is calculated using balanced chemical equations and is based on the Law of Conservation of Mass. Theoretical yield is the maximum amount of product that can be formed, while actual yield is the amount obtained in real life. Stoichiometry ensures that the total mass of reactants equals the total mass of products.
MorQQ
sulfuric acid dissolves aluminum metal according to
2 Al(s) + 3 H2SO4 ---- Al2(SO4)3 (aq) + 3 H2
find minimum mass of H2SO4 in g if you wanted to dissolved aluminum block with mass of 15.2 g
see above
15.2 g Al x 1/26.98g x I am confused about molar ratios what do i use? x 98.09 g H2So4
could someone help me with molar ratios i don't understand what to multiply by
Look at the reaction equation - how many moles of acid needed for 2 moles of aluminum?
1. What is stoichiometry?
Stoichiometry is the study of the quantitative relationship between the reactants and products in a chemical reaction. It involves calculating the amount of substances consumed and produced in a reaction.
2. Why is stoichiometry important?
Stoichiometry allows us to predict the amount of products that will be formed in a reaction, as well as determine the amount of reactants needed for a desired amount of products. This is crucial in industries such as pharmaceuticals and agriculture.
3. How is stoichiometry calculated?
Stoichiometry is calculated using balanced chemical equations, which show the ratios of reactants and products in a reaction. The coefficients in the equation represent the number of moles of each substance involved.
4. What is the difference between theoretical and actual yield?
Theoretical yield is the maximum amount of product that can be formed according to stoichiometric calculations. Actual yield is the amount of product obtained from a reaction in real life. The difference between theoretical and actual yield is known as the percent yield.
5. How does stoichiometry relate to the Law of Conservation of Mass?
The Law of Conservation of Mass states that matter cannot be created or destroyed in a chemical reaction. Stoichiometry is based on this law and ensures that the total mass of reactants equals the total mass of products in a reaction.
14K
