What is the method for deriving Stokes' law for drag around a sphere?
The discussion centers on deriving Stokes' law for drag around a sphere, specifically addressing the pressure and viscous stress contributions. The pressure equation indicates that integrating pressure around the sphere results in zero net force, as the pressure on opposing sides cancels out. It is emphasized that in Stokes flow, the only drag arises from viscous forces, not pressure, due to the low Reynolds number that keeps the flow attached to the sphere. A distinction is made between viscous and inviscid flows, noting that pressure can contribute to drag in inviscid scenarios, unlike in Stokes flow. The conversation concludes with a clarification that Stokes flow does involve both viscous and pressure drag components, although the latter is negligible in this specific case.
fayled
So you can solve the Stokes equation for flow around a sphere to obtain the pressure in the fluid:
p=p0-3nuacosθ/2r2
where n is the viscosity, u is the speed of the fluid (along the z axis) far away from the sphere, a is the radius of the sphere and r,θ are the usual spherical polar coordinates.
We can also obtain an expression for the velocity field u=(ur,uθ,0) which I won't type here because I'm only concerned about the general principles of something.
My question is about the method for deriving Stokes' law for drag, F=6πnau. The method I have seen is to use the velocity field to work out the viscous stress tensor, which allows you to compute the stress (as a vector) on the sphere due to the fluid. This vector can then be integrated over the sphere to give the required drag force.
However, I don't understand why we can't just integrate the pressure*(-r/r) i.e multiplied by its direction of action on the surface of the sphere, the radial unit vector, and integrate this over the sphere to give the drag force. I have tried and it doesn't seem to give the same result (you don't need to perform the integral, only need notice that the stress vector and the vector obtained from the pressure are not equivalent).
Thanks for any help :)
If you integrate the pressure around the surface in Stokes flow you should get zero. The pressure on the front and back should exactly cancel, if I recall. The only form of drag on a sphere in Stokes flow is viscous, and since viscous drag has nothing to do with the pressure, it shouldn't surprise you that you can't derive it from the pressure distribution.
After all, look at the pressure equation you cited. If you integrate that over ##\theta = [0,\pi]##, you get zero.
Ok - it doesn't surprise me that it's to do with the flow being viscous as opposed to inviscid, as I have used the pressure approach to find say the lift in inviscid flow. So why exactly does pressure give rise to drag and lift in inviscid flow and not viscous flow?
It gives rise to drag in viscous flow, it's just that Stokes flow is a special case. The Reynolds number is so low that the flow remains attached around the sphere the entire way. In general, this is not the case. If you had a higher Reynolds number, you would end up with a wake behind the sphere with a lower pressure than in front of it, thus resulting in pressure drag.
I think this is incorrect. The pressure drag around sphere for potential flow is zero.
For Stoke's flow you have contribution from friction (2/3) and pressure drag (1/3).
http://user.engineering.uiowa.edu/~fluids1/Creeping_flow_1.pdf
Likes Chestermiller
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
