Strange Gearbox: Old Factory Maintenance Engineer Needs Help
  • Thread starter Thread starter maxx_payne
    Strange
A maintenance engineer discovered an unusual gearbox in an old factory machine, resembling harmonic drives but functioning differently. The gearbox transmits motion from the motor shaft via a key to bearings, which then transfer motion to elliptical gears solely through bearing rotation. The bearings rotate smoothly, raising questions about the design and functionality of the gearbox. The engineer seeks insights or information from others who might recognize this type of gearbox. Additional visual documentation, such as pictures, could aid in identifying the mechanism.
maxx_payne
hello everyone i am a maintenance engineer in old factory so while we were working on an old machine yesterday we found a very strange gear box like the harmonic drives but it transmitts the motion from the motor shaft by a key to bearings those bearings transmitts motion to a elliptic shaped gears only by bearing rotation although the bearing can rotate smoothly
if anyone has an idea about this gear box pls help me
Pictures?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
12K
