Sum to Infinity: Solving the Limit of a Series
In summary,In order to find the sum to infinity, Daniel needs to differentiate the power series for \ln(1-x) and use the result to find the sum of the series for \ln(1-x).
crazedbeat
Hello!
Here is the problem I am attempting:
Sum to infinity:
[tex]\frac{x}{1*2} + \frac{x^2}{2*3} + \frac{x^3}{3*4} + ...[/tex]
Here is what I get:
[tex]S = \frac{x^n}{(n)(n+1)}[/tex]
[tex]\lim_{n \to \infty} \frac{x^n}{(n)(n+1)}}[/tex]
Now what? Should I do partial fractions to split the equation?
No,you should say the domain of "x"...You're interested in getting the value of the limit,right...?
Daniel.
I am trying to find the sum to infinity. Why should I do the domain of x?
Because it involved a limit for which telling in which domain "x" takes values is ESSENTIAL...
Daniel.
I was not given any range of domain? Do I make up one. Essentially it can be anything...its in the numerator..
It counts.If it's in [itex] \left[0,1\right] [/itex],the limit is 0.If it's in [itex] \left(1,+\infty\right) [/itex],then the limit is [itex] +\infty [/itex]...
The tricky part is when "x" can be negative.
Daniel.
So if I take sum from negative infinity to positive infinity, all the places where x is raised to an odd power will get canceled out. So only those which are left would be the one with the even power...which I take the sum of. However, how do I get the sum of the even power? i.e. how do I start this problem?
I was thinking one thing:
The power series is as such:
[tex]e^x = \frac{x^n}{n!}[/tex]
Could I use this? All that's different about what I am doing is that there is also (n+1)! in the denominator.
So would I just do:
[tex]e^x * \sum_{n=0}^\infty \frac{1}{(n+1)!}[/tex]
That would not help here. And you do not have factorials in your original S.
Also, I hope you know that what you have labeled S is just the nth term of the serie. This is different from the nth partial sum. Evaluating the limit you have written will not give you the sum of the limit. All you can conclude from this limit is the range of points x where it does not converge (when lim does not equal 0), and the one where it MAY converge (when lim = 0).
But limit is only equal to 0 when x = 0...
Could someone kindly guide me in the right direction...I am really confused
Here's the result.
[tex]\sum_{k=1}^\infty \frac{x^k}{k(k+1)}=\allowbreak \frac {1}{2}x\left( 2\frac{1-x}x-\frac {2}{x^2}\left[ \ln \left( 1-x\right) \right] \left( x-1\right) -\frac {1}{x-1}\left( -2x+2\right) \right) [/tex]
I don't know how Maple did it,though...
Daniel.
I think you should differentiate your series.
If u do what Hurkyl said,u'll bump into this series
[tex] \sum_{k=1}^\infty \frac{x^{k-1}}{k+1}\allowbreak \allowbreak =\allowbreak \frac 1{x-1}\frac{1-x}x-\frac 1{x^2}\ln \left( 1-x\right) [/tex]
Daniel.
P.S.I think you'll find useful the Taylor series for [itex] \ln (1-x) [/itex] around 0.
Why must one diffrentiate to this? I thought I was looking for the sum. Doesn't this do different all together?
Nope,the result of the differentiation will be another series which can be computed more easily...
Daniel.
What does this series have to do with anything:
at least this one has the correct left hand side:
But how is any of this to be evaluated?
Differentiate the general term [itex] \frac{x^{k}}{k(k+1)} [/itex] wrt "x" and the u'll get the general term for the first series...
Daniel.
Perhaps I should explain first that our professor did not cover a lot of this stuff, I am an ECON major, and have been fiddling through a book which does not cover series. (Everything I know is through research online. And none of it makes sense.)
Daniel.
Oh alright that makes sense then. :rolleyes:
Now if I plug in one, I get a lot of illegal values, i.e. 0 in denominator and ln(0)...so I diffrentiate again for a better series?
Sorry then for my persistance.I thought u wouldn't give up.
Daniel.
No.That is the result.The sum of the series which,obviously depends on "x".That result should tell u however "the illegal values of <<x>>"...That "x" has lots of restrictions.
You should integrate now to get the original series.
Daniel.
No, no, I really appreciate your persistance. But could you just explain it a little bit to me? You have to understand I know very little about series-- only that I am suppose to add numbers. The first example I did, my friend did it with limits, so I thought that ALL could be done with limits. Now there is diffrentiation, which is just not makign sense :( and I feel like I am getting nowhere.
Series,under certain conditions,especially of convergence,could be differentiated and integrated term by term.That's what it's done here.First u differentiate the original series to get another series which is simpler to evaluate.Then,u have to integrate back to get the original result.It's a very elegant method,but which only works,as i said,only if the series you get at each step are convergent...
Daniel.
Ooo. I see. But we haven't figured out the diffrentiated thing yet, so we shouldn't go back yet? If we go back and try and solve, we'd be nowhere, no?
Or have we figured it out and I completely missed it? Or do we integrate the simple thing and that'll give an answer? But what's the gurantee the simple thing integrated won't be complicated?
A common technique in mathematics is to transform a problem into something simpler, that you know how to solve.
In this case, you wanted the sum S(x), but as it turns out, S'(x) was simpler, and you were able to solve it.
Now, all you have to do is to recover what S(x) is, given that you now know what S'(x) is.
Hello...?
Make the substitution
[tex] k+1=u [/tex]
in the series
[tex] \sum_{k=1}^{\infty}\frac{x^{k-1}}{x+1} [/tex]
and write the new series in terms of "u".
Daniel.
What is the concept of "Sum to Infinity" in mathematics?
The concept of "Sum to Infinity" refers to the calculation of the total value of an infinite series, also known as a sequence, which involves adding an infinite number of terms together. This concept is used in calculus to find the limit of a series, which is the value that the series approaches as the number of terms increases infinitely.
How do you solve the limit of a series?
To solve the limit of a series, you can use several techniques such as the Ratio Test, the Root Test, or the Comparison Test. These tests help determine whether a series converges or diverges, and if it converges, what value it approaches. Additionally, you can also use algebraic manipulations and mathematical identities to simplify the series and find its limit.
What is the significance of solving the limit of a series?
Solving the limit of a series is essential in many areas of mathematics, including calculus, differential equations, and statistics. It allows us to calculate the exact value of a series, which can have practical applications in fields such as engineering, physics, and finance. Moreover, understanding the limit of a series is crucial in understanding the behavior of functions and their derivatives.
Is it possible for the sum of an infinite series to be a finite number?
Yes, it is possible for the sum of an infinite series to be a finite number. This occurs when the series converges, meaning that its terms become smaller and smaller as the number of terms increases. In this case, the sum of the series approaches a specific value, which is the limit of the series. However, not all infinite series converge, and some diverge, meaning that their sum approaches infinity or negative infinity.
Are there any real-life applications of "Sum to Infinity"?
Yes, there are several real-life applications of "Sum to Infinity." For example, in finance, the concept of compound interest involves the calculation of the sum of an infinite series to determine the future value of an investment. In physics, infinite series are used to approximate complex mathematical expressions, such as the value of pi. Additionally, the concept of "Sum to Infinity" is also used in signal processing, power series, and many other areas of science and engineering.
