Sums of Independent Random Variables
WHB3
Vicki owns two separtment stores. Delinquent charge accounts at store #1 show a normal distribution, with mean $90 and std. deviation $30, whereas at store #2, they show a normal distribution with mean $100 and std. deviation $50. If 10 delinquent accounts are selected randomly at store #1 and 15 at store #2, what is the probability that the average of the accounts selected at store #1 exceeds the average of those accounts at store #2?
Let X1=N(90,30); where n=10, XBar1=N(90,30/10)=N(90/3). Let X2=N(100,50); where n=15, XBar2=N(100,50/15)=N(100,3.33)
We need P(XBar1-XBar2>=1)=P((XBar1-XBar2+10)/Sqrt(-.33))>=(1+10)/Sqrt(-.33)
=11/(Sqrt(-.333))? This doesn't make any sense to me!
Any assistance would be very much appreciated!
hmmm... haven't done much probability for a while
but based on your sampling I would try & come up with a probabilty distribution for the average of the measurement...
so to start, say we pick X n times, then let Y be the average of the n samples, so the random variable Y is given by:
Y = (X +...+ X)/n (sum of n times)
What is the expected value & variance of Y, assuming each picked X is independent? Shouldn't be too hard to calculate... (though independence is an important assumtion...)
If you have done this for both cases, then consider independent the random variables Y1 & Y2, how do you find the probabilty of Z = Y1-Y2 >0.
Maybe something similar to first process, to find expectation & variance, then sums of guassian distributions are also gaussian...
I see what you're saying, that the sample means should reflect the multiple of the sample size. However, don't I still end up with a denominator equal to the square root of minus 1/3?
After several more attempts (and re-reading your analysis), I think I finally solved the problem. Thanks, Lanedance!
good one, glad it worked
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
