Calculating Mass Increase of Earth in a Day Due to Solar Energy
The discussion focuses on calculating the mass increase of Earth due to solar energy, given an intensity of sunlight at 1.5 kW/m^2. The initial calculations estimate the energy received by Earth in a day, resulting in a mass increase of approximately 3.67 x 10^5 kg. However, a correction is noted that the light should be treated as coming in parallel, requiring the Earth to be considered as a disk rather than a sphere. This adjustment leads to the conclusion that the mass increase should be halved. The participant acknowledges the correction and recalls similar guidance from their lecturer.
quietrain
At Earth’s location, the intensity of sunlight is 1.5 kW/m^2. If no energy escapes
Earth, by how much would Earth’s mass increase in a day? (Radius of Earth is
6.37 × 10^6 m.)
ok so, at anyone time, half of the Earth is lit.
so surface area lit = 1/2 x 4\Pir2 =
2.55x1014m2
intensity = 1500 W/m2
so energy per second on Earth = 1500 x 2.55x1014 = 3.82 x 1017 J
energy per day = 3.82 x 1017 x 60 x 60 x 24 = 3.3 x 1022
so E = mc2
so m = E / c2 = 3.67 x 105 kgbut the correct answer is half of this. so where did i go wrong? thanks for help!
You are treating the light as being perpendicular to the surface area of the sphere, but it's not. The light comes in parallel. (Treat the Earth as a disk, not a sphere.)
ooo! thanks a lot doc! now i remembered my lecturer said this too !
