How to Find the Magnetic Field on the Axis Between Two Co-axial Current Loops?
Welshy
Two co-axial, parallel, circular wires of radius R each carrying current I are placed a distance 2d apart. Find an expression for magnetic field B on the axis at distance e from the midpoint between the two loops up to and including terms of 0(e3).
The field for one such loop was calculated to be:
B = (u0IR2)/(2(z2+R2)(3/2))
I'm not sure how the superposition works at all. I've seen it in a few past papers and the method isn't in my notes or the course textbook. (Introduction to Electrodynamics, Griffiths)
Any help or hints on the method would be greatly appreciated!
Superposition is nothing more than the ability to calculate the magnetic field due to either ring and then add them up together (vectorial). So the first thing you should do is put yourself a distance e from the midpoint. Express the distance to said point in terms of z,d,e for both loops. Then check the direction of the magnetic fields, do they amplify each other or weaken or is there an angle between the field lines etc.
Hmm. What I get is:
B = (u0IR2cos(O)/((d2+e2+R2)(3/2))
where O is the angle between the (e to centre of coils) vector and the z axis and the B vector is in the z axis. I'm not sure if that's right because I don't see how that can be expanded to powers of e in any way.
From this I understand that the point e lies on the axis that goes through the center of both rings. Assuming this is the case I don't see how you get a cosine in your answer.
This is the configuration we are talking about as far as I can see.
|-----|--e---| ---------------------> (positive z-direction)
x''''''''''''''''''''''''''''x
the . is where the magnetic field comes out of the "paper" and the x is where the magnetic field goes into the "paper". I have assumed that both currents run in the same direction.
Now try to answer the following questions with regards to point e.:
Left ring
1)In what direction does the magnetic field point in point e?
2)What is the distance z from the center of the ring in point e?
Right ring
Same questions as for the left wing.
3)Do the fields of both rings point in the same direction in point e, are they parallel to each other?
Now enter the data in Bleft and Bright and add them together (vectorial).
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
