Surface density of stars in a Galaxy
The scale length of a galaxy's disk is defined as the distance over which the surface density of stars decreases by a factor of e. In this discussion, the surface density decreases by a factor of 10 over 9 kpc, leading to a calculated scale length of 9 kpc. The formula for surface density is σ(r) = σ0e−r/h, where σ0 is the central surface density and h is the scale length. A participant questions the assumption that e equals 10, indicating a potential misunderstanding of mathematical constants. The conversation highlights the importance of accurately interpreting the relationship between surface density and scale length in galactic structures.
Barbequeman
The surface density of stars in a galaxy at a radius of 1 kpc from the centre is 100 Msun/pc^2. The surface density at 10 kpc is 10 Msun/pc^2. Assuming that the surface density of stars is given by the exponential law, calculate
(a) The scale length of the disk.
(b) The surface density at the centre of the galaxy.
σ(r) = σ0e−r/h
a.)
The scale length of the disk is the length over which the surface density of stars decreases by a factor of e. In this case, the surface density decreases by a factor of 10 over a distance of 9 kpc, so the scale length is 9 kpc. The surface density of stars at a radius of r from the center of the disk is given by: σ(r) = σ0e−r/h where σ0 is the central surface density and h is the scale length of the disk. We can rearrange this equation to solve for h: h = −r/ln(σ(r)/σ0) plugging in the values from the question, we get: h = −9 kpc/ln(10/100)
h = 9 kpc
Ummm, back up a second. So you are saying that ##e = 10##?
