Surface Integral of Vector fields
dancingmonkey
Use Stokes' Theorem to evaluate ∫C F · dr. C is oriented counterclockwise as viewed from above.
F(x, y, z) = (x + y^2) i + (y + z^2) j + (z + x^2) k
C is the triangle with vertices (9, 0, 0), (0, 9, 0), and (0, 0, 9).
Stokes' Theorem
I really need help with this, can someone explain it to me?
Do you know what Stoke's theorem says?
If you honestly are not able to make any attempt at all then you need more help than we can give. I recommend you talk to your teacher about this. Quite frankly, if you know what Stoke's theorem says, this is very easy problem.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
