Surface Integral With Divergence Thm
Karnage1993
Let ##\mathit{F}(x,y,z) = (e^y\cos z, \sqrt{x^3 + 1}\sin z, x^2 + y^2 + 3)## and let ##S## be the graph of ##z = (1-x^2-y^2)e^{(1-x^2-3y^2)}## for ##z \ge 0##, oriented by the upward unit normal. Evaluate ##\int_{S} \mathit{F} \ dS##. (Hint: Close up this surface and use the Divergence Theorem)
It's clear that ##div \ F = 0##, so if I was working with a closed surface, ##\int_{S} \mathit{F} \ dS## would equal 0. For the graph of ##S##, I am unsure as to what "closing up" a surface means. How would one close up a surface?
Add the surface z=0 to creates closed surface. Then, the divergence theorem gives the surface integral of the sum of the surfaces; subtract the integral over what you added to get the surface integral of the desired surface.
Ok, so what I think you're saying is I have to do:
##0 - \int_{plane \ z = 0} F \ dS##
which will get me only the surface integral of the graph of z?
Yes. And you'll need to pick the correct direction for the normal vector for the surface z=0.
For it to be outward pointing, would the z-component have to be negative, ie, (0,0,-1)?
Exactly.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
