Surface Integrals and Gauss's Law
5 replies · 2K views
Brennan999
When I learned Integrals in Calc III, the formula looked like this
∫∫ F(r(s,t))⋅(rs x rt)*dA
but in physics for Gauss's law it is
∫∫E⋅nhat dA
How are these the same basic formula? I know that nhat is a unit vector, so it is n/|n|, but in the actual equation, it is a dot between the cross product and E.
The problem is I don't know how they are the same since Gauss' Law wants E dot a magnitude, when a surface integral is F dot the vector cross product? They don't seem to be following the same rules
Yeah, I get that you need to cross them to get the perpendicular vector of the surface.
Basically, the surface integral eq in full form is
∫∫S F ⋅ (rs x rt)/|(rs x rt)| *(rs x rt) dA
and for Gauss's Law it is
∫∫S E⋅n/|n| dA
so you can see in the first one it simplifies to the cross product as a vector,
but the second one simplifies to the unit vector (because of dividing in magnitude) in the direction normal to the surface.
I don't get how these are equal
The general notion is a surface integral over a vector field,
$$I=\int_{F} \mathrm{d}^2 \vec{f} \cdot \vec{V}(\vec{r}).$$
Here ##\mathrm{d}^2 \vec{f}## is a vector on a infinitesimal surface element which is perpendicular to the surface and its magnitude is the area of this infinitesimal surface element.
To evaluate such a surface integral, one possibility is to parametrize the surface with two generalized coordinates
$$F: \quad \vec{r}=\vec{r}(q_1,q_2).$$
In the most simple cases the ##q_j## run over a rectangular area in a plane, ##(q_1,q_2) \in [a_1,b_1] \times [a_2,b_2]##. Then
$$\vec{T}_j=\frac{\partial}{\partial q_j} \vec{r}$$
defines two tangent vectors along the surface, and the infinitesimal vectors $$\mathrm{d} q_j \vec{T}_j$$ span an infitesimal parallelogram. Then from the geometric meaning of the cross product, it's clear that
$$\mathrm{d}^2 \vec{f}=\mathrm{d}q_1 \, \mathrm{d} q_2 \, \vec{T}_1 \times \vec{T}_2$$
are the surface-element vectors according to this parametrization of your surface. You get
$$I=\int_{a_1}^{b_1} \mathrm{d} q_1 \int_{a_2}^{b_2} \mathrm{d} q_2 [\vec{T}_1(q_1,q_2) \times \vec{T}_2(q_1,q_2)] \cdot \vec{V}[\vec{r}(q_1,q_2)].$$
It's pretty easy to show that the value of the integral is independent of the parametrization (up to a sign, which you have to carefully specify anyway by choosing the orientation of the surface by your choice of the order of the generalized coordinates).
