PeterDonis
Mentor
- 49,047
- 25,128
JVNY said:But there appears to be an agreed upon definition of simultaneity for observers riding on a rotating disk (thus for any observers riding on a radius of a rotating disk). WannabeNewton refers to it, and the Vallisneri piece illustrates it.
Are you referring to the Marzke-Wheeler definition? I'm not sure I would call that one "agreed upon". It does have some nice properties, but it's not the only convention used in the literature. And for the rotating ring case, it has two obvious drawbacks: (1) the surfaces of simultaneity are different for each different observer on the ring, and (2) none of those surfaces match up with the simultaneity surfaces of an observer who is moving with the ring's center of mass.
JVNY said:And that definition appears to say that the riders on a radius do not agree on the simultaneity of distant events even along the line of the radius.
Yes, that's true of the Marzke-Wheeler convention.
JVNY said:Using the convention of sending light signals from the hub can cause the clocks to be set to a given time simultaneously in the lab frame, but everyone says that this does not set them to the given time simultaneously on the disk.
Not with either the "momentarily comoving" simultaneity convention or the Marzke-Wheeler convention, no. But those are not the only possibilities.
JVNY said:So it does not seem right to say that there are just different conventions and leave it at that.
Why not? The convention you adopt makes no difference to the results of any experiments; different conventions result in different coordinate charts being used to assign coordinates to events, but the predictions for all observables are the same.
