Tangent planes passing through coordinates origin.
Alteran
The problem from Differential Geometry:
Let \gamma : R -> R is smooth function and U = {(x,y,z) \in R^3 : x \ne 0} - open subset.
Function f : U -> R is defined as f(x,y,z) = z - x\gamma(y/x) and this is smooth function.
Proof that for surfaceS = f^{-1}(0) all tangent planes passing through coordinates origin.
Can anyone give me a hint?
You mean to say:
"Prove that for the surface f-1(0), all tangent planes pass through the origin"
What have you tried so far? What definitions are you working with? I defined a set V = {(x,y) in R² : x not equal to 0}. Then I found a smooth regular surface patch \sigma : V \to \mathbb{R}^3 such that \sigma (V) = f^{-1}(0). Writing it this way, I found it easy to find the tangent planes to the surface, and then easily showed that each of those tangent planes pass through the origin.
Yes, exactly - "Prove that for the surface f-1(0), all tangent planes pass through the origin".
I have found tangent planes for this surface, but how to show that they are passing through the origin? I need to show, that these planes are defined in (0,0,0)? or something else?
A plane is just a set of points. Show that for each tangent plane, (0,0,0) is in that plane, i.e. (0,0,0) is in that set of points. For example, the point (1,0,y(0)) [I'm writing y instead of gamma] is in the surface. The tangent plane at this point is the plane:
{a(1,0,y(0)) + b(0,1,y'(0)) + (1,0,y(0)) : a, b in R}
I need to show that the origin (0,0,0) is in this plane, i.e. that there exist real a and b such that:
a(1,0,y(0)) + b(0,1,y'(0)) + (1,0,y(0)) = (0,0,0)
But that's easy:
a=-1, b=0.
Is there any part of this you didn't understand?
Thanks for support. I think now I can catch what is going on. I was little bit confused :blushing:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
