Maximizing Tangential Deceleration for Cars in Corners
  • Thread starter Thread starter Jason03
    Deceleration
The discussion focuses on calculating the maximum tangential deceleration for a car entering a corner, with the maximum deceleration before the corner identified as -8 m/s. The user has determined the normal acceleration (A_n) to be 7.5 m/s using the formula A_n = v^2/r. They are attempting to find the tangential acceleration (A_t) after entering the corner, which they calculated to be -2.78 m/s. The conversation also touches on the use of logarithmic functions and the need for clarity in mathematical notation. Overall, the challenge lies in understanding the dynamics of deceleration in cornering versus straight-line driving.
Jason03
Im trying to figure out the maximum deceleration possible for a car coming into a corner at two points...
I found the answer to the max. deceleration for the car right before the corner, but I can't get the correct answer for when the car is actually in the corner...
im looking for the maximum Tangential decerlation after just entering the corner...
the max. for right before the car enters is -8m/s
Just looking for a strategy...
m = 1500kg
v = 15m/s
r = 30
max friction = 12,000N
i guess i stared long enough
it was: a^2 = a_n^2 + a_t ^2
where a_n = v^2/r
a_n = 7.5 m/s
so we know the total a = -8m/s
find a_t when car is entering corner
a_t = ( (a^2) - (a_n^2) )^.5
a_t = -2.78
hence you are able to decelerate much better on a straight than in a corner...
can u put the equations into brackets so i know that its eg v^(2/r) or (v^2)/r. i haven't done this sort of stuff but it looks like you could just use logarithm functions to work it out.
[when a=m^b b=(log(base 10)a)/(log(base10)m), LnA=B and A=e^b]
hope that helps!
actually this makes it more clear
Normal Acceleraton = A_{n} =\frac{v^2}{r}=
magnitude of total Acceleration
A = \sqrt{A_{n}}-{A_{t}}
solve for A_{t}
Im still working on learning the syntax for using latex...
Actually this makes it easier:
Total Magnitude of Acceleration
A = \sqrt{A_{n}}-\sqrt{A_{t}}
Solve for A_{t}
what are the values for the known letters? have you tried using simultaneus equations with logarithm functions? sorry i can't be of much help.
