Tangential Force Required to Slow Cylinder to a rest?
The discussion focuses on calculating the tangential force required to stop a massive grinding wheel in a paper factory within 80 milliseconds. The initial angular velocity is converted from 62 rpm to radians per second, leading to an angular acceleration calculation. The moment of inertia for the solid cylinder is correctly identified as I = 0.5mr², which is used to derive the tangential force. The final calculation yields a tangential force of approximately 219,000 N, emphasizing the importance of significant figures and proper sign conventions. The conversation highlights the need for clarity in applying physics equations and understanding rotational dynamics.
ObviousManiac
a)-The massive grinder for wood-pulp in a newsprint paper factory, which can render about a half Tonne of wood into a thin soup in less than a minute, is essentially a stone cylinder of radius 0.900 m and mass about 6.00 Tonnes. An enormous motor spins this cylinder on its axis while hydraulic cylinders press the pocket of wood against its rim. A typical rotational speed for the motor is 62.0 rpm (rotations per minute). Suppose that while the paper plant is in full operation there is a power outage due to an ice-storm. How much energy (in J) is available to grind wood just from the rotational kinetic energy of the grinding wheel?
I HAVE ALREADY SOLVED PART a,
NEED HELP WITH B:
b)-If the grinding wheel comes to rest in 80.0 ms what is the tangential force (in N) that the wood presents to the grinding wheel if this force is constant during the slowing down?
KE = 1/2Iw2
F = ∆p/∆t ...?
t = Fr
∆w/∆t = α
honestly don't know where to start.
Hi ObviousManiac! :smile:
First find the angular acceleration, using the standard constant acceleration equations but with θ ω and α instead of s v and a.
Then find the torque that produces that angular acceleration, and so find the force at the rim. :wink:
Silly question - what is my θ?
there's no θ in this particular question, only the angular equivalent of u v a and t :wink:
to find α, could I not do this?:
wf = wi + αt
wf = 0, so
-wi = αt
(where wi = 62 rpm/60 sec * 2π rad = 6.49 rad/s)
so
- 6.49 = α(.08)
α = -81.125 rad/s2
looks good! :smile:
and so the tangential force is … ? :wink:
T = mr2a
= 6000(.92)(-81.125)
= -394267.5
rF = -394267.5
.9F = -394267.5
F = -394267.5/.9
F = - 438075 N
... Is this correct?
ObviousManiac said:
T = mr2a
No, that's the wrong I.
Also, it would be easier (and quicker, and less likely to lead to mistakes) if you wrote all your equations at the start …
in this case, Fr = τ = Iα, so F = Iα/r :wink:
isn't I = mr2 ?
So would it be
F = Iα/r
F = mr2α/r = mrα
yes :smile:, except I for a solid cylinder isn't mr2
you need to learn the moment of inertia of every common geometrical shape :wink:
OH
I didn't even think about that... wow I'm really dropping the ball tonight.
So:
I = .5mr^2
F = Ia/r
f = .5mr^2a/r = .5mra
= (6000)(.9)(-81.125)/2
= -219037.5 N
