Calculating Average Acceleration of a Tennis Ball During Contact with the Floor
  • Thread starter Thread starter barobinson630
    Ball Drop Tennis
To calculate the average acceleration of a tennis ball during contact with the floor, first determine its velocity just before impact using the initial height of 4.36 m and the acceleration due to gravity (9.8 m/s²). Next, calculate the velocity at the moment of rebound from the height of 2.45 m. The change in momentum during the contact time of 10.0 ms can then be used to find the impulse applied to the ball. By dividing the impulse by the contact time, the average acceleration can be derived. The discussion highlights the importance of understanding momentum and impulse in solving the problem.
barobinson630
You drop a tennis ball from 4.36 m. It rebounds to height of 2.45m. If the ball is in contact with the floor for 10.0 ms, what is its average acceleration during that contact?
we know initial height to be 4.36 m
acceleration due to gravity to be 9.8 m/s^2
contact for 10.1 ms
rebound height of 2.45 m
Im completely lost, don't know where to start
Start by finding the velocity of the ball just before it hits the floor and just after it bounces off the floor.
Welcome to PF barobinson630!
Given the initial height, you can figure out the velocity of the ball upon impact. From that, you know its momentum just before hitting the ground.
Given the maximum height it reaches on the rebound, you can easily figure out its velocity at the instant of leaving contact with the ground. So you know its momentum just after the collision.
So, you know the change in momentum of the ball that occurred as a result of the contact force from the ground. If you know the change in momentum of the ball, then you know the impulse that was supplied to the ball (since these are the same thing). You also know the time interval over which this impulse was applied...
nevermind...i figured it out
thank you though!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
