Tension and centripital force HELP
  • Thread starter Thread starter warmfire540
    Force Tension
The discussion revolves around calculating the minimum speed required for a 2.0 kg ball attached to two strings to ensure the lower string becomes taut while whirling in a horizontal circle. The key concept is that when the lower string is not taut, it effectively does not contribute to the tension, and the ball's radius of rotation increases until it matches the length of the lower string. Participants clarify that the tension in the upper string can be resolved into components, leading to the calculation of the angle and the necessary speed. The calculations provided suggest that the minimum speed is approximately 5.66 m/s, and the tension in the lower string is calculated to be around 74.6 N. Understanding the forces at play, including gravitational and tension forces, is crucial for solving the problem accurately.
warmfire540
A 2.0 kg ball is attached to a vertical post with two strings, one 2.0 m long and the other 1.0 m long as shown in the figure. If the ball is set whirling in a horizontal circle, what is the minimum speed necessary for the lower string to be taught? If the ball has a constant speed of 6 ms-1, find the tension on each string.
| \ -2.0m
|----0 -2.0kg
| ^1m
I don't exactly understand what this means, I've tried tackling it several ways.
Only thing I can figure is that when the string is taught it is at maximum centripetal force. However I'm not sure how to find this.
I have so far
F(centripetal)=mv^2/r
F=2v^2/1
F=2v^2
your equations are correct, but there is no maximum centripetal force in this case.
To find out when the bottom string becomes taught:
image that the bottom string isn't there (when its not taught, it effectively isn't - it doesn't do anything). As the ball speeds up, it will move further out (increasing radius) from the pole (i.e. the angle between the pole (vertical) and the top string will increase). When the radius of rotation reaches the length of the bottom string (1m), the bottom string will be taught.
Its probably easier to find this in terms of the angle afore-mentioned.
Draw free body diagram
total 3 forces acting:
1. gravitational
2: Tension 1 (upper)
3 tension 2 (lower)
The resultant of the three forces is providing the necessary centripetal force.
Tension must be greater then zero.
solve accordingly.
do these answers comply?
For the first part, figured that the 2m string has two components of tension Tsin60 and Tcos60.
Tsin60=mg=19.6
Tcos60=mv^2/r=2v^2
tan60=19.6/2v^2
v=5.66 m/s
is that right? I calculated the angle that the 2m string made w/ the x-axis and went from there...
Now..for the second part..
i figured that the tension in the 1m string is the centripital force which is:
T=mv^2/r=2*36/1= 72N
Now for the second string..what would the tension be?
i'm guessing i have to use the Tsin60 and the Tcos60
Tsin60=19.6N
Tcos60=72N
T=sqrt(19.6^2+72^2)
T=74.6N
