Tension of a string between 2 blocks of equal mass on a flat surface
The discussion centers on calculating the tension in a string between two blocks of equal mass being pulled by a force of 17 Newtons. Participants emphasize the importance of using free body diagrams and Newton's Second Law to derive the tension. The equations indicate that the tension can be calculated by considering the forces acting on each block. The solution involves recognizing that both blocks will have the same acceleration due to their equal mass. Overall, the problem is deemed straightforward once the proper approach is applied.
livereater
What is the tension of a string between 2 blocks of equal mass that are moving due to a pull of 17 Newtons?[PLAIN]http://postimage.org/image/pmoibsy4p/ [/PLAIN]
A. 8.5
B. 0
C. 17
D. 25
F=ma
Attempt at a solution is not just 17... haha... Show your equations that you used, so we can help you... Did you draw your FBD's for the 2 masses?
Very easy once you have done the equations for both the masses...
This is a very straight forward problem.
Newton's Second Law!
If you draw a free body diagram of each block you will have:
ƩFBLOCK1=ma
FPULL - T = ma
ƩFBLOCK2=ma
T = ma
You are given that the masses are equal to each other and the system will accelerate at the same rate!
Yes Bill Nye Tho, for you it is very easy, but the purpose of this forum is to help people understand what they deal with by letting them do the problem themself, we just aid them when they struggle... Try helping not just showing that you know the answer...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
